How are the carptets fastened into the car?
Old Nov 7, 2002 | 06:28 AM
SuPeR SpOrT's Avatar
How are the carpets fastened into the car, are they glued? tacked? what? I am going to pull out the carpet and clean it... so I need to know how...
ALso how do I get teh seats out?
Old Nov 7, 2002 | 06:42 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Glue. Seats some out with a 13 or 14mm socket. 4 nuts on each front seat, 1 bolt holds each rear seat bottom, and there is 1 nut on both sides of the rear seatback(s), at the bottom. You also need to take off the seatbelt retainers (Front = screwdriver, Rear =T??? Torx) Not sure what size Torx, but its small.
Old Nov 7, 2002 | 07:53 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
the front seat belts in every third gen I've worked on has been a torx like t45 or 50 a big one.
Old Nov 7, 2002 | 08:23 AM
Scott_92RS's Avatar
Car: 1992 RS
Ooops, my bad, I didnt even think about the floor mounted part I was talking about the guide that is on the front seat. The bottom belt reel is attached using a T45, T50, or T55 torx bit, not sure which one, but its a big one.
Old Nov 7, 2002 | 08:37 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Thats ok I forgot all about the seat belt guides being there.
Old Nov 7, 2002 | 11:54 AM
what kind of glue is the carpet held in by? ? ?
Also how can I get the old carpet out without ruining it because I want to clean it and then reinstall it...
Old Nov 7, 2002 | 12:23 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
My carpet wasn't held in by any glue-or none that caused any problems pulling it out anyway!
Remove all seats, front seat belt reels (torx 50), door sill plates, centre console, seat belt buckles. Everything on top of it needs to be removed. Then just pull it out. It won't be easy to pull out because of all it's contours, but just keep pulling it from various places! Putting it back is the reverse of removal!
Check out the photo for the state of my carpets! And they cleaned up very well.
http://andyfanshawe.freewebspace.com/interior_state.JPG
Old Nov 7, 2002 | 12:27 PM
Scott_92RS's Avatar
Car: 1992 RS
You probably wont ruin the carpet by taking it out, but you may ruin the foam padding. If you are careful and pull slowly, you probably wont have any problems. Even if the padding sticks to the floor in some areas, you will still be able to glue the carpet back to it. You can buy the carpet glue at auto parts stores, all of them I've seen have it in stock. It comes in a red can I think, made by 3M.
My suggestion is to not even take the carpet out just to clean it. You will have PLENTY of room to manuver in there once the seats are out. Get a few cans of upholstry cleaner and go at it. It'll take a lot less time to do and you'll have similar results, IMO.
Old Nov 7, 2002 | 12:36 PM
CDN_87IROC's Avatar
Another suggestion ... hit the weight room for some bicep work. It takes a strong arm to remove the seat belt bolts.
Old Nov 7, 2002 | 01:45 PM
Ill keep that in mind thanks guys
Old Nov 7, 2002 | 02:43 PM
FLYNLOW92rs's Avatar
I dont have any glue in my carpet..........
It would make sense to just remove the seats and some panels if you are just going to clean it, when you replace it, then you take everything out.......
Old Nov 8, 2002 | 06:25 AM
what would I do if the bolts are rusted to ****, how would I get them off?
Old Nov 8, 2002 | 08:20 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
if the bolts are really rusted...nail em with some WD40 and let it soak in, jack up the car and get under it if you have to...the bolts go through. just make sure you get the torx bit seated down into the head of the bolt, push it in with your hand, lean on it. get a breaker bar or use a wrench or pipe to get some more leverage on the ratchet. it'll come out...ive had to bust quite a few loose in the junkyard.
Old Nov 8, 2002 | 01:36 PM
i c
I will try that thenn
Old Nov 8, 2002 | 02:50 PM
aklaim's Avatar
What if the torx bit that holds the seatbelt to the floor is stripped? How would somebody get that out? I was looking through my car and it seems the previous owner completely stripped that bolt.....
Old Nov 8, 2002 | 02:58 PM
Scott_92RS's Avatar
Car: 1992 RS
1. Try turning it from the threads under the car.
2. Drill it out.
3. Weld a nut to it.
4. Try forcing something into the hole and get it to turn without slipping.
Thats all I can think of.
Old Nov 8, 2002 | 05:21 PM
aklaim's Avatar
2. Drill it out.
Thanks. When the time comes I'll give one or all of those a shot
Old Nov 9, 2002 | 03:12 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Hammer + next size up torx bit
Old Nov 9, 2002 | 08:38 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I'm pretty sure the size for the seatbelt holddown is a T-47. Was a pain in the butt to get it out, but after some expletives, a new T-47 bit, some vice grips and about 5 minutes it came out.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
