Console Removal
Old Nov 7, 2002 | 01:42 PM
luke7786's Avatar
Console Removal
I wanted to remove my console in my GTA to repair the sides of it. I was wondering what I needed to take off, unscrew, disconnect. etc to remove it. Thank you for you tips.
Old Nov 7, 2002 | 02:25 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Take the u pin out off the t-handle and pull that and the e-brake handle off. Then open ther console lid inside the console theres two 10mm bolts, take those out and on the plastic part (shift plate) theres two 7mm bolts take them out too , disconnect your power window switches shift light lighter wires, ect. might be a good idea to label em' then theres a metal bar going across the console bolted to the shifter 10mm i think then just manuvere around the shifters an it'll come out , if you really wanna take the radio pod out you can but its no nessecary.
Hope this helps
Old Nov 7, 2002 | 06:33 PM
luke7786's Avatar
How exactly do you take the top of the parking break, and the shifter off? I really dont see anything.
Thanks for the help.
Old Nov 7, 2002 | 06:41 PM
Should be a screw on the left hand side , toward the console , if yours is leather wrapped there is a hole just stick a phillips head screwdriver in there and turn youll feel it come out then pull it out and slide it up and off
Old Nov 7, 2002 | 08:10 PM
luke7786's Avatar
Ok
I have taken all the screws off, and have taken the parking break cover off. Now I am working on the shifter. I cant find any phillips head screws in there. I have looked in the hole in the leather on the drivers side, and have looked in the leather in the hole on the A/C control side. I still cant find anything. PLEASE HELP!!! Thank You
Old Nov 7, 2002 | 08:30 PM
In the shifter there is a u clip that clips into the front toward the radio You said you got the e-brake handle off right.. what else did you get off.
Old Nov 7, 2002 | 08:34 PM
luke7786's Avatar
I got off the two screws off that where in the glove box, I got the two on the shift plate, and I got the one under the ash tray. So how do I go about getting these clips off? Thanks for the help
Old Nov 7, 2002 | 08:58 PM
gw47129's Avatar
Shift Handle removal
I have a leather warpped shift handle on a 91 Z28 convt
I do not see any holes for screws or retainer clip on the shaft
I do not want to damage the leather
Any suggestions on how to get it off?
Old Nov 7, 2002 | 09:02 PM
well GW is it the round kind w/ the button on top or the squareish kind with the button on top
Luke what clips are ya talking about the ones that clip onto the window switches? those ya take each hand and use your nail to bull back the clips on each side and push the switch off .. its a pain but its doable
Old Nov 7, 2002 | 09:05 PM
gw47129's Avatar
shift handle removal
It is a square handle with a square button
Old Nov 7, 2002 | 09:14 PM
Here i did a search on it and this is from CaysE i just gonna quote him instead of givin ya the link
"You have to push the **** down first. Then take off the button and take off the c-clip that keeps the **** from flying off. Then it slides up and off."
Old Nov 7, 2002 | 09:24 PM
gw47129's Avatar
OK I tried, but the leather shift **** does not move down on the shaft. It moves up and down about a 1/16". It feels and sounds like there is a keeper ring inside at the bottom of the leather ****. I tired with the shifter in all gear positins and with the button depressed. No luck
Any suggetions on what I anm doing wrong?
Old Nov 8, 2002 | 11:07 AM
luke7786's Avatar
Ok, here is what I found. On the radio side of the shifter you will find a hole in the leather. That metal thing inside is a clip that is holding the shifter in place. So have to use alot of force (probably using needle nose pliers) to yank the clip out. Once it is out, the shifter cover will come off. I hope this helps.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Fronzizzle
Sep 8, 2015 12:10 PM
