Front end damage ... How bad is it ?
Old Dec 25, 2002 | 03:04 PM
jim86's Avatar
I bought i Z28 pretty cheap a couple years ago cause it had some damage to the passenger side front end. I have another front bumper and another hood for it, still need to pick up the fender. The only thing i did not plan on doing myself was straightening out the radiator core support which is slightly bent. I'm not sure what something like that costs or what's involved. I've attached a zip file with some pics, if anyone could take a look and give any insights on whether this is easily doable or maybe more involved than i think. thanks ......
Old Dec 25, 2002 | 07:02 PM
Big Jon's Avatar
Jim
your file did not attach. maybe you could just post one of the top of the rad. suport and inner fender? From what you describe, it should not be too hard.
Old Dec 25, 2002 | 09:05 PM
jim86's Avatar
Sorry about that ... exceeded file size. Should be here now, thanks.
Old Dec 25, 2002 | 09:08 PM
jim86's Avatar
And another ....
Old Dec 26, 2002 | 12:13 AM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
that isnt the radiator support,my front end was crushed and my radiator was fine,that is your headlight bracket. its one piece taht goes across,it bolts through the front clip to the fenders. youll need a new fender. the front end piece could be used again, mine was in worse shape n i did all the bidy work to fix it.its not hard to do at all.
Old Dec 26, 2002 | 12:20 AM
MdFormula350's Avatar
doesnt look that bad... i would go ahead and fix it as long as it doesnt have any frame damage.
Old Dec 26, 2002 | 07:49 AM
Big Jon's Avatar
the core support does not look too bad in the pics. It looks like the fender gave more than anything. I would try to pull it out yourself. The easy way is to use a come along and try to pull it out the way it went in. your pull will need to come up slightly. I would use a tree and put your chain around the tree about a foot higher than the radiator support, and gently pull it out. be careful not to get in the way of the ratchet, and work the creases out as it comes forward. I hope I haven't lost you on my explanation.
Jon
Old Dec 26, 2002 | 10:13 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thats not bad at all.
This is a car I just picked up to fix for a buddy. He hit a 2002 cady doing about 15mph.
Pulled the old clip ina few hrs and had this one one the same night.
Next is to swap the gfx for 91-92 also.. and rims. then the rest of the body work, new p.side door and fix the dent in the rear.
Old Dec 26, 2002 | 10:14 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
After
Old Dec 26, 2002 | 10:33 AM
good work!!
Old Dec 26, 2002 | 01:36 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I agree, good work.
Old Dec 26, 2002 | 03:18 PM
IROC-Z5.7TPI's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Transmission: 700 R-4
Where do you guys think a good place to get a whole new front clip is. Everything in Front of the Honey Comb Bumper. Its for the car described in my sig, IROC that is.
Old Dec 26, 2002 | 05:35 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Local Junk yards, some let ya walk around and pull what you want.
Or call 1-800-CAMARO-1 Its Camaro Heaven they should have what you need.
Old Dec 26, 2002 | 05:59 PM
83crossfireZ28's Avatar
tpi383: have you considered changing the rest of the ground effects? it may just be me, but it looks a little wierd with the bigger ground effect with the smaller ones. i have an 84 camaro i was thinking about fixing up with a broken ground effect, then i bought a wrecked 85 that happened to have a good one, but it was bigger...
Old Dec 27, 2002 | 03:57 PM
jim86's Avatar
Thanks for the info guys... Big Jon, i get what your saying. I'll try that when it's a little warmer up here
Jim
Old Dec 27, 2002 | 11:20 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi All,
Attached is picture of my 82 Bird sitting on the Flatbed that took it to the repair shop on Dec 11th.
Old Dec 27, 2002 | 11:30 PM
BruceEmbry's Avatar
Hi Everyone Again,
Attached is picture of my 82Firebird's engine carpartment.
See how clean it is!. Yes that 350 Tune Port Fual Injected monster. All Orginal new GM Parts were use when I had it put in less then 5 years ago.
Old Dec 28, 2002 | 01:21 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Originally posted by BruceEmbry
Hi All,
Hey what rims are those?
Old Dec 28, 2002 | 10:36 AM
BruceEmbry's Avatar
Hey what rims are those?[/B]
The Wheels are ten years old. They were made by American Racing. They had the proper offset for the Firebird. Since one of the wheels were damaged in the accident, I now have to replaced all four wheels. These wheels are no longer available.
I have already purchased new wheels and tires. The wheels are 16x8 AT Italia 5 Razzas. The tires are BF Goodrich Comp TA 245/50 VR-16s. Please see attachment
Old Dec 28, 2002 | 11:33 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ya thats what Im doin next and some other body work.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bellez77
Sep 5, 2015 08:39 PM
LittleFranks
Aug 20, 2015 03:55 PM
