fourth gen interior
Old Dec 29, 2002 | 06:08 PM
armymp1983's Avatar
fourth gen interior
i am thinking about putting a fourth gen interior in my camaro.
i HAVE already used the search button and read the other articles. i nee to know how the speedo and gauges work. can you use fourth gen guages??????
will the hook up with the 3rd gen cables.???
has anyone done this????
many of these articles explain the basics of installing the dash and door panels but not really much on the electrical side????
Old Dec 31, 2002 | 11:00 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I believe you can use the fourthgen guages. You simply have to figure out the wiring scheme. The colors are different across the board but everything you need to make it work is as I understand it present in our cars. I saw a write up somewhere on the specifics. But I can't remember where. I wish I could tell you exactly how to do it. I know it can be done.
Old Dec 31, 2002 | 11:02 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Try contacting Fatal88...He may be able to answer your questions.
Old Dec 31, 2002 | 01:48 PM
Fatal88's Avatar
Car: 1988 Z
you will have to modify your wiring harness. Some things won't work with the 3rd gen harness.
Old Dec 31, 2002 | 02:11 PM
CrazyHawaiian's Avatar
Car: too many ...
I remember seeing a drawing that gave you the schematics on wiring a 4th gen guage cluster to work with a 3rd gen ECU. Sofa King made it I believe. Try searching more.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
