t-top prob
Old Jan 9, 2003 | 05:08 AM
70formula's Avatar
t-top prob
I recently purchased an 87 GTA that came with t-tops, but I found out my t-tops are aftermarket and installed by a bodyshop called "Roman Chariot" in Cleveland, OH. I found out recently that many dealers sent out their "new cars" to aftermarket bodyshops to install t-tops sold/made by a company called "Cars and Concepts". They are a bit different than the factory installed t-tops. I was told that this company also produced the original t-tops for GM.
Unfortunately, this company is no longer in business, so I am having a hard time finding molding, rubber, etc. My t-tops look pretty close to the originals except I have ouside molding on both the front and back going across the car (left to right) on the outside of the car. Does anyone else out there have this type of a t-top? Is there a company out there selling something identical? I checked with a couple of dealerships that knew squat about this. Any ideas would be helpful. Thanks in advance.
Old Jan 9, 2003 | 08:08 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Surprisingly enough, no-one has chimed in to tell you to do a search, as this topic pops up now and again. http://www.sunroofdoctor.com/ has posted on their website that they purchased the last remaining C&C inventory, and they have the entire kit to convert a car to t-tops as well. HTH!
Old Jan 9, 2003 | 12:55 PM
70formula's Avatar
I did a search under "t-tops" and found 50,000,000 topics on t-tops (mild exaggeration). I went thru about 3 or 4 pages of t-top stuff before giving up.
Thanks for the posting. I will definitely check it out.
Old Jan 9, 2003 | 12:59 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Try searching for "aftermarket ttops" and "C&C ttops" that might narrow down your search some.
Old Jan 9, 2003 | 02:03 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
so how much for the door weather stripping??? i need some new stuff and i have factory t-tops.
Old Jan 9, 2003 | 02:29 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I have C & C tee tops on my car. Dont know about the other company. Check with The Sunroof Doctor.
Old Jan 9, 2003 | 10:21 PM
MdFormula350's Avatar
http://www.hawksthirdgenparts.com/weatherstripping
Old Jan 10, 2003 | 02:49 AM
slick00m's Avatar
Car: 1989 Camaro IROC
Engine: 6.0 LQ9
how do i tell if my t-tops are factory or not? I read 70formulas explanation, but i did not quite understand it.
Ryan
Old Jan 10, 2003 | 03:05 AM
70formula's Avatar
From what I've found the easiest way is to measure the glass length from front to back. C&C are 28" while the GM Fishers are 30 1/4". C&C also have an outside front and back moulding that goes across from left to right. I ordered some headliner locking moldings today along with a cap from the "sunroofdoctor". not expensive at all - quite impressed. I spoke to them for about a half an hour and now I'm an expert.
Thanks cg91ta for the lead. I knew I came to the right place.
Old Jan 10, 2003 | 07:22 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
You can tell factory from aftermarket just by looking at them.
When looking at the car the gap between the windshield and the T-top is about the same as the Door "A" Pillar then they are FACTORY t-tops.
IF the gap between the windshield and the T-top is about TWICE as wide as the "A" Pillar then you have the C&C top.
John
Old Jan 10, 2003 | 11:55 PM
slick00m's Avatar
Engine: 6.0 LQ9
I never did think that mine were aftermarket, but then i read this post and it scared me. any way, mine is about as far away as the a-piller, and they are about 29" wide. But im pritty sure that they are factory. About the molding, do you meen that the molding on the front and back on aftermarket goes all the way across the top of the car?
Thanks for the help,
Ryan
Old Jan 11, 2003 | 06:29 AM
bjm323's Avatar
Car: '91 Camaro RS
Are you sure Roman Chariot is out of business?? I will post a link just in case........
Roman Chariot
Old Jan 11, 2003 | 02:00 PM
C&C tee tops have writing on the inside rear corners of the glass. They do have a little weatherstipping on the front and rear of the tee tops that run from one side of the car to the other. It took me nearly a year to get that little bit of weatherstripping over here in Aus. I used a small piece of rubber until I got the correct pieces. Mother of inventions.
Old Jan 11, 2003 | 11:43 PM
HamSpiced's Avatar
tee tops.....what are those....????
my car has T-Tops
Old Jan 12, 2003 | 11:58 AM
70formula's Avatar
bjm323 - never said Roman Chariot was out of business. What I was talking about was "Cars and Concepts".
Good news - I was told by a Pontiac dealership that the aftermarket C&C t-tops actually leak less than the factory ones. Actually, mine don't leak at all.
I'm pretty happy that the sunroof doctor had my parts.
Old Jan 12, 2003 | 01:20 PM
My C&C tops only leak a little when using the high pressure at the car wash. I put new weatherstrips on 3 years ago.
Old Jan 13, 2003 | 02:18 AM
slick00m's Avatar
Engine: 6.0 LQ9
well then, mine must be factory cause they leak a lot. oh well, i need to get new weatherstriping for my entirer car.
thanks
Ryan
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
