need help!!!! please look...
Old Jan 15, 2003 | 09:30 PM
Kandied91z's Avatar
to save you the long story and get straight to the point!
how can i jump the power window switches so that i can roll the windows up without hurting anything??? i have no power to any accessories.
engine is gone so there is no harness grounding the fusebox so even with a battery the acc are dead...please help!!!!
:hail:
Old Jan 15, 2003 | 10:20 PM
2vmodular's Avatar
acquire a spare car battery, tie the negative terminal to a good chassis ground and the positive terminal to the pink wire on the switches.
this thread may also be of intrest:
https://www.thirdgen.org/techbb2/sho...hreadid=149137
Old Jan 15, 2003 | 10:47 PM
Kandied91z's Avatar
so can i use the stock ground wire i use for the negative terminal on the battery and just run an extended power wire up to the center console where the switches are and touch it to the pink to make it work??
my battery is in the back, so i figure i'd just run an extension of the power up to that lead to make the switch lower or raise the window....is that correct?
Old Jan 15, 2003 | 11:53 PM
90 Z28SS's Avatar
Yes
Thats exactly what I did when my car was tore apart .
Old Jan 15, 2003 | 11:57 PM
Kandied91z's Avatar
oh thank the lord.....now my car won't be covered in a nasty thick dust like it was the last time it ventured to the shop.
you sure the wire will be pink?
Old Jan 16, 2003 | 12:03 AM
90 Z28SS's Avatar
Yeah , the pink wire is the main power supply wire for the switch . Just make sure the black wire is grounded .
Kandied's car = SCARY ....at the moment neways Same color ?
Old Jan 16, 2003 | 12:11 AM
Kandied91z's Avatar
yeah....just alot more custom touches. although most are in the driveline!!
i plan to post some pics when she's completed in 4-5 weeks.
Old Jan 16, 2003 | 12:15 AM
Kandied91z's Avatar
would the current ground cable i use for the battery work or do i have to ground it another way?
Old Jan 16, 2003 | 02:24 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
as long as the ground is connected to the chassis, all you need to do is run the power to the pink wire. It doesn't matter where the ground connects to the body, so long as it does connect to the body.
Old Jan 16, 2003 | 05:57 AM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
wow is that a new pic? your painting it again?
Old Jan 16, 2003 | 09:56 AM
Kandied91z's Avatar
alright.....how do i jump the power hatch motor?
is it possible?
Old Jan 16, 2003 | 04:14 PM
Kandied91z's Avatar
windows worked like a charm....broke a 5 dollar switch to try and get them out. but it worked...thanks everyone!!
techno101
Mar 20, 2015 04:23 PM
GreggymacZ28
Jun 7, 2014 12:34 AM
MOTO RR
Wheels and Tires
Jun 4, 2014 11:00 PM
58mark
Aftermarket Product Review
Apr 4, 2014 09:07 AM
'87 IROC VERT
Car Audio
Nov 29, 2005 06:49 PM
