GFX emblems
Old Jan 18, 2003 | 10:35 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
GFX emblems
Okay quick question, will RS emblems fit in Z28 gfx? I found a set of Z28 gfx that I really want but they are from a Z28 and since my car is an RS I want to go back to that.(It has iroc gfx now)
Old Jan 18, 2003 | 10:51 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Yes, all 85-90 gfx are the same it doesnt matter if they came from a Z28,IROC,88 CAMARO,RS all the same. More than likely when you take off your RS emblem the two studs on the back of the plastic emblem will break off so you might need to use some weatherstripping adheasive or doubble sided adheasive tape to attach the RS emblem to your new gfx.
Old Jan 18, 2003 | 11:54 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If your RS badge is Teal and silver, I have a brand new one here in my room you can have.
Old Jan 19, 2003 | 12:34 AM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Sorry I did not specify, hopefully it does not make a difference, the gfx I found are from a 91-92 car. Will it make a difference? Oh and as far as the emblems go I want the gray and black ones.
Old Jan 19, 2003 | 09:36 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Anyone??
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Anyone?
Old Jan 19, 2003 | 09:45 PM
Car: 85 Camaro SC
Engine: V6
It shouldnt matter. The shapes of the emblems look or are the same, so just try doing a test fit. They should be the same it wouldnt make sense to gm to make different emblems for the 91-92's and not use the same design as the 85-90's.
Old Jan 19, 2003 | 09:50 PM
1982chevycamaroz28's Avatar
on 91-92 z28s the emblems are kinda like stickers almost and the stick on. they arent like the ones that when u pull them off have the 2 posts behind them.
Old Jan 19, 2003 | 09:53 PM
Car: 85 Camaro SC
Engine: V6
They still have the black plastic trim piece that attaches to the gfx and the emblem goes ontop of that right?
Old Jan 19, 2003 | 10:09 PM
no on the 91-92 z28s the emblem is kinda recessed into the ground effect so when u stick the emblem on its kinda flush but not. like it fills the recessed area.
Old Jan 19, 2003 | 10:32 PM
Car: 85 Camaro SC
Engine: V6
Ok I see now. Thanks I now know the complete difference, got any close up pics of the different emblems?
F-body-fan
Jan 12, 2023 01:49 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
2012sergen11
Oct 13, 2015 07:38 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
ASE doc
Sep 22, 2015 03:13 PM
