Instrument cluster
Old Jan 22, 2003 | 06:27 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Instrument cluster
I did a little search here and found some neat things and cool setups already done by people. I want to build an instrument panel out of aluminum to house my Auto Meters guages I have out of an older project car. I have a ( you guessed it!!) 92 Z28. The factory instruments are attached to a printed circuit looking thing. Is it possible to retain my check engine light and turn signal indicators? Can I simply go through the wires and pick and choose what I need? I don't see why not, I just want some feed back from others who have done it. Thanks in advance.
Old Jan 22, 2003 | 07:46 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
That is a good question. I am not sure if the warning lights are ran off of a smaller voltage, or not. I didn't use any extra lights on mine besides the turn signals and high beam light.
Old Jan 23, 2003 | 12:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
I do not believe the turn signals and indicator lights are run off less volatgae then 12. If I where you, I would find a beat up gauge cluster out of any car in the junkyard and use the decals in the cluster for the signals and stuff and glue them to pre cut holes in the aluminum panel with a light behind it. Getting a light to stay on the panel will be your idea, Cant help ya there. I say this because I wouldnt want to cut up a perfectly good dash cluster from a 92z28. I have the correct color coded wires for all the dash stuff. My car is a 91 so your shouldnt be too far off. The chiltons book has the 1992 models all by themsleves for some reason and I had to use both years (91-92) to do my 4th gen dash swap
Old Jan 23, 2003 | 04:57 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I haven't had the dash appart in a long time. Last time I was in there was to change out some bulbs like two years ago. I am not all that concerned with the high beam indicator, only the turn signals and mostly the check engine light. I figured on using some of those small 1/4or 3/8 inch LED for that.
Can the wires I require for the indicator lights and things like the fuel guage simply be disconnected from the factory setup and changed to the lights and guages I want?
4th Gen dash, huh? That sounds purtty kewl!!
Old Jan 23, 2003 | 05:45 PM
johnsjj2's Avatar
Car: 1991 Z-28
Hey 92zzz28,
I have a pdf file with the cluster pinouts if you would like it. I used 1/4 lights for my turn signals from Radio Shack. They work great. Let me know if you want me to e-mail that file to you.
Old Jan 23, 2003 | 06:53 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Sure that would be great. Thanks.
mustangmasher@yahoo.com
Old Jan 23, 2003 | 09:44 PM
BOTTLEDZ28's Avatar
Transmission: A4
can you send that file over this way too? I would to take a look at it
Old Jan 24, 2003 | 01:26 PM
johnsjj2's Avatar
Car: 1991 Z-28
On its way.
Old Jan 24, 2003 | 07:52 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Ebay look...
If you go to Ebay and do a word search "camaro dash" you can find cutouts already made out of aluminum for about $17.Hope this helps.You can also do a search by seller.Look for the seller name speedhut.He has cutouts for various cars including 3rd and 4th gen camaros.
Old Jan 24, 2003 | 09:37 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
johnsjj2
THanks for the info. I really appreciate it.
Ryan
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
James Sutton
Sep 23, 2015 01:56 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
