Finally mock fitted those "Euro" M3 side mirrors... (Dial Uppers Beware)
Old Feb 10, 2003 | 07:38 AM
scauffiel's Avatar
I don't think I like them, unless I do some "modding."
These are pix of it attached directly - meaning at the same angle that the "black triangle" sits:
Stand by for more.
S.
Old Feb 10, 2003 | 07:39 AM
scauffiel's Avatar
With some modification...
These pix are of it attached NOT at the same angle as the black triangle. This would require a wedge of some sort to make it sit level with the car/parallel with the ground. This I like more than the previous look - but I still think the casing may be too "bulbous" for the car.
*sigh* Let's hear it. If the only thing you have to add to the thread is to call "r<x>ice" do yourself a favor and just hit the "Back" button.
Steve
Old Feb 10, 2003 | 07:49 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Great mod! I love the turn blinker in those, but agree that the mirror itself may be to large. I like the mirror setting level with the ground vs tipped up.
What is the object in the sail panel? Looks like a bolt head/slot.
Old Feb 10, 2003 | 07:55 AM
scauffiel's Avatar
Originally posted by cg91ta
Great mod! I love the turn blinker in 'em. I like the modded mod better. The mirror setting level with the ground vs tipped up.
What is the object in the sail panel? Looks like a bolt head slot?
Keep us updated as this progresses!
Yeah, I like it level much better, but still think it's too bulbous. The object in the sail panel is my power antenna.
S.
Old Feb 10, 2003 | 08:08 AM
BTS88IROC's Avatar
I'll just start by saying I love all the work you've done to your car. I love you ingenuity (sp?) However, I honestly don't really like the way that mirrow looks, it sticks out too far for me. It looks alot better in the second set of pics, but I've seen others with different mirrors (redraif) and it just doesn't do it for me. I haven't really seen anything yet that looks better than the stock 3rd gen mirrors IMO. But its your car, keep up the great work
Old Feb 10, 2003 | 10:12 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
personally i think it looks cool as all hell.... i remember the post you did about making the antenna flushmounted a while back and that was really cool, it looks awesome now. i like those mirrors alot i just dont like that they sit cockeyed (look at them from drivers seat) im actually thinking of taking my stock camaro ones off and putting the 4th gen ones on like how i think fatal did on his. that looks cool as hell..
Old Feb 10, 2003 | 10:14 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I don't think it looks too bad at all. Whats that car under the cover in the background?
Old Feb 10, 2003 | 11:45 AM
smurfmobile's Avatar
nope don't like it , the mirror looks too "fat" , lol
there are tons of others out there , try some for integras, those should be a bit smaller and more elongated than the fat m3 one you have on there
Old Feb 10, 2003 | 12:13 PM
jawzforlife1's Avatar
your car is looking great, I really like the attenna idea. But when I look at the 2nd pic, that shows the old and new mirriors, I like the old ones alot better. The new ones are too boublely.
Old Feb 10, 2003 | 01:03 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I think it looks better with it level with the ground. I had thought of doing this with the stock mirrors. Never looked into it that much beside checking out just the lights they sell seperately. Could you possibly take, say a Dremel with a cut-off wheel and cut out a hole for one of these lights? Is there even enough room behind the mirror shell before you would hit the actual mirror? I don't know, never took one out to see. Just an idea! I am sure you could pick up a set of used mirrors for cheap, take all the paint off ,and then cut away. No? I still think the concept looks good though. Keep up the good work man. Later
Old Feb 10, 2003 | 01:35 PM
scauffiel's Avatar
Well, thanks for the looksee fellas. I may look into Corvette mirrors, or just keep my eyeballs open as I drive around. We'll see. Shannon did the fourth gen mirrors that looked really good, but I thought they appeared just a bit too small and sort of out of proportion. 'Course, I went the other way and got a couple that are a bit too fat...
MetalliCamaroRS: That's a '68 Firebird under the car cover; it's a wreck and will be parted out here shortly.
Smurfmobile: I'll look into the Integra mirrors.
Jawsforlife1: Roger that on the bubbly look. LOL
86IROCNJ: I agree with you on the level ones looking better. As far as putting your own lights in, it should be possible. IIRC, there is a ton of space behind the actual mirror on the stockers.
S.
Old Feb 10, 2003 | 02:04 PM
spike1856's Avatar
Car: '86 SC
Engine: '88 2.8L
I actually like the shape of that mirror (in the second fit, not the first)... but I HATE the turn signals in them. I can't stand that, it looks horrible!
If you had mirrors that shape without the lights (And maybe a tad bit smaller?), that would rock
Old Feb 10, 2003 | 02:13 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Steve, neat idea, but it looks like *** and doesn't look like it would function from your drivers seat.
Try something else
Old Feb 10, 2003 | 02:44 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Steve:
I like the second try better than the first.
Also, I think the only thing that is not working for me is how far they stand off from the car. I have a similar opinion on the 4th gen side mirrors. Anyway, if you're still fishing for suggestions I'd say try moving the mirror closer into the body and it might look more appealing to you.
Old Feb 10, 2003 | 03:11 PM
scauffiel's Avatar
"Hate" is such a powerful word spike. I'm not a big fan of them either and wouldn't run the "turn signal" wiring, just the parking light. 'Course, you may not be a fan of that either, in which case, uhhhh, oh well.
Mike: I'm not sure what you mean. So, you like it and think it would work well? Tell me how you really feel.
Jim: The second variation is my favorite of the two; now I've just got to make a wedge, paint the whole shebang one color and try it again. I don't think they stick out too too far, they just look too bulbous.
S.
Old Feb 10, 2003 | 03:20 PM
Originally posted by scauffiel
[Btoo bulbous.
[/B]
:sillylol:
Old Feb 10, 2003 | 07:19 PM
thirdgen89rs's Avatar
scauffiel, i would liek to talk to you about some of the mods you did other than the sideview mirrors (BTW they look great). Send ya a pm im deffinately interested in knowing more about some of the stuff you did, thanks if you can help me out.
Old Feb 10, 2003 | 08:21 PM
25THRSS's Avatar
great car man, looks badass! keep up the good work
Old Feb 11, 2003 | 06:05 AM
CrazyHawaiian's Avatar
Car: too many ...
I think it looks great. Thats exactly what I had planned to do, only I was going to try a set of 'Euro M3' mirrors for the fox body mustangs (made by APC). I've just been too busy with the body of the car (gettn ready for a paintjob!) My only concern was if the piece the mirrors mount to can hold up at high speeds (assuming they're bolted in). What car were those mirrors made for? PM me if you dont want them anymore and you'd like to sell em.
Old Feb 11, 2003 | 07:38 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
i don't really like these mirrors. even on M3's. but hey, you want euro mirrors?
Old Feb 11, 2003 | 08:52 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
i think it looks good but i'd do a little be more moding because for some reason to me the mirror looks a little tilted to the upward directing it doesn't look like it's sitting flush with the door you know what i mean? maybe tip it down a little to make it look like it's suppose to be there.
Old Feb 11, 2003 | 09:39 AM
scott's85T/A's Avatar
I agree that the 2nd set of pics. look alot better than your first.
If you could get them attached level like that they will look good,, but, I don't like the lights in them,, there to big.
NO offence.
Old Feb 11, 2003 | 10:31 AM
I think that mirror is just not a good shape. Need to find something with different lines that match better.
Old Feb 11, 2003 | 11:20 AM
scauffiel's Avatar
I PM'd ya back, brother.
Originally posted by 25THRSS
great car man, looks...
Thanks man!
Originally posted by CrazyHawaiian
I think it looks great. Thats exactly...
The mirrors were the "universal" type and they bolt up to that triangle which is, I believe, metal covered in rubber. At least it feels like it's rubber encased metal. Just like Shannon said, it's quite sturdy and should take a good amount of abuse.
Originally posted by Freeze
but hey, you want euro mirrors?...
Ummm, no thanks, but it looks good on you though.
Originally posted by transam305
doesn't look like it's sitting flush...
Yeah, that's why the second set of pix gets more thumbs up, because it's level with the ground - and that's the way I'll go if I decide to go with it.
Originally posted by scott's85T/A
but, I don't like the lights in them...
Well, what I'm actually considering doing to the lights is light sanding them to make them opaque. I'd like to make it look like they were "acid etched" or... well, I can't think of a good example right now, but suffice to say they'd look "cloudy" to blend in with the (eventual) pearl white paint.
Originally posted by pennylessz28
Need to find something with different lines...
Like...? You see, getting a response like this doesn't help me much. There've been several "find another style" posts, but no on has posted a pic, a definite model, or anything. Saying "try again" isn't too constructive. Saying "try again with a 1995 Corvette convertible - here's a pic" is much much better; more importantly it's constructive and adds to the knowledge base here on thirdgen. I asked for opinions, so just saying "they suck" is, while not productive, fine - but when you step up with "they suck, try something else;" you better bring something to the table. I realize I'm here for the endless amusement of the users here , but as you all know time is valuable and I don't have all the time (or money) in the world to try every combo of mirror.
Sorry for the soapbox and I'm not picking on you Mike, even though you've said it twice now , but it's just something that irks me when reading posts - be it on this board or others. It's okay to criticize a problem if you've got an idea for a solution. Else, you're just adding to the melee.
I've looked at a couple of the Integra mirrors and I think they'd be too small - though it's hard to gauge online what they'd look like. A co-worker owns an M3 which is why I could eyeball that to see if it'd be a good size.
Steve
Old Feb 11, 2003 | 12:07 PM
In my personal opinion, time to get out some fiber glass knowlegde.
I've fiddled with this idea before. Well photoshoping anyhow, never actually found one and attempted.
I really think the stock ones look best, but if that were the case for you, you wouldn't be asking opinions now would ya.
In all the pictures it looks like the angle is gonna be tricky for you and you mentioned having to figure out how to make a wedge to mount it.
It kinda looks like it sticks out to far. I think the unpleasing thing that makes it not flow right is the way it tear drops.
What about triming the edge so it rids closer and more even to the window sill? This might give the illusion of the tear drop edging into the fender side more.
See the more I like at it it does look ok, but I think the gap is the thing that keeps drawing my eyeball. If its pushed to the coner where the door meets, just like you have, and maybe shaved a few cm's off to bring it tighter, I think it might look really good.
But I'd photoshop that first. before I go shaving the thing. IF it looks horrible, crap.
4th gen mirrors look good too, but you have to consider how they mold into the fender, so, I dunno.
BTW, you can find a transloucent white paint at the hobby shop, if you polish those sides, and then paint the car and use the transloucent white, it might just blend so well you won't know its there till its lite.
I work with the Marines everyday. I know how you guys like your stuff.
Old Feb 11, 2003 | 12:40 PM
here is a photoshop of the mirror brought closer to the car. Looks better IMO, but I still lock the stock ones better.
Attached Thumbnails Finally mock fitted those &quot;Euro&quot; M3 side mirrors... (Dial Uppers Beware)-bird-mirror-2.jpg
Old Feb 11, 2003 | 12:42 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
With the wedge I think it makes a big difference. If you could also tilt them back (i.e. front to back, not perpindicular to the car) a little, then I'd really like them. They just look like they're tipping toward the front of the car right now. You might have to reshape the triangle area for them to look right tilted back, but overall I think it'll be a lot better.
Old Feb 11, 2003 | 01:01 PM
89firechicken's Avatar
you could probalbly make the mirrors sit flush like the first pic but cut the supports make the top one longer and the bottom one shorter so the angle of the mirror will sit flush with the ground. at least thats what i would anyway. oh i like the second pic and all of the mods you've done great job.
Old Feb 11, 2003 | 04:04 PM
firebird13's Avatar
Hey that car is looking great,..hate to steel your thread but is there any way i can put a front bumber on my car like scauffiel..I got a 87 pontiac firebird..can i just swap off the one on it now and put one on it or will i have to do a lot of moding..and molding? thinks for help
adam throop!
Old Feb 11, 2003 | 04:35 PM
Xceleratemaro's Avatar
i think thats the best looking trans am i have seen in my life... that deserves a moment of silence...........................................................................................................................................................................................................................................................................................................................................................................................................................wow you have done a grate job.. i dont think anyone on here could do that good:hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail:
i think they would look good with the wedge in it ....
Old Feb 11, 2003 | 07:49 PM
IROC57TPI's Avatar
Why can't you just take the lights out of the mirrors and mount them in the stock mirror housings? I think that would look
Old Feb 11, 2003 | 09:07 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
and yet another amazingly awesome mod by scauffiel! That car is going to be amazing when its done, its amazing already! Keep up the nice work man.
Old Feb 12, 2003 | 07:20 AM
scauffiel's Avatar
Jim85IROC: I may be a bit thick this morning but I'm not sure I get ya. Do you mean bring the front "point" more outboard, away from the car?
89firechicken: Yeah, that thought crossed my mind, but once I do that then I'm done if it doesn't work; they won't be fixable.
firebird13: Uhhh, all of the stuff on my front bumper is custom done by me. Now if you mean the actual "nose cone" then, yeah you can buy it and put it on, but it won't have the lights or holes for the fogs. If you don't have ground effects on the rest of your car, it may look kind of goofy too.
Xceleratemaro: Well.... Thanks brother! I'm not sure it's the BEST looking car on the planet, but I sure do like it.
IROC57TPI: You could, but that's pretty expensive just to add some lights to your mirrors. I got these for $50 through eGay not knowing if they would work or not, so I pretty much considered it "throw away" money. I'd find another way of doing the lights to stockers if that's what you like.
82firebird: Dude... That's a lot of amazing. Not to mention, who said it'll ever get done?
Thanks for the ideas and opinions fellas - I guess I'll be working some wedges this weekend!
Steve
Old Feb 12, 2003 | 08:27 AM
transam305's Avatar
i have to agree i think no matter what you do to that car it is always amazing i wish i could get my car to look that good. what else do you have in mind for future mods?
Old Feb 12, 2003 | 09:13 AM
Jim85IROC's Avatar
If you're looking at the car from the side, the front of the mirror looks like it's higher than the back of it. I mean tilt the whole thing forward, not closer or farther from the car. Bring the front point closer to the ground. KnowhatImean?
Old Feb 12, 2003 | 09:20 AM
IROC57TPI's Avatar
I think what Jim is trying to say is to level the light with the lines of the car. Its not straight its crookid.
Old Feb 12, 2003 | 09:26 AM
scauffiel's Avatar
Oh, gotcha. I couldn't get the damn thing to stay there without using clamps and electrical tape, and that was haphazard (I could feel the mirror just waiting for me to get out of a "quick lunge" range) so that was the best I could do.
She'll be level prior to any drilling. Heh heh. LOL
S.
Old Feb 12, 2003 | 10:56 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I like it since i see these mirrors almost everyday. They are really popular over here.
Old Feb 12, 2003 | 12:37 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
What kind of spoiler is that? Second set of pics looks better than the first.
Old Feb 12, 2003 | 12:57 PM
Jim85IROC's Avatar
It's a 4th gen spoiler. Steve was one of the first to do it, and he did it by modifying a stock 4th gen piece. Since then GTAuto produced them to fit on a thirdgen. If he ever gets himself out of jail, you might be able to buy one too.
Old Feb 12, 2003 | 01:56 PM
transam305's Avatar
was it vary hard to get the spoiler on? how much did it cost? can you still get them? i want one lol. sentence fragments gets the job done HAHA!
Old Feb 12, 2003 | 08:09 PM
  #42
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
I love 'em. The 2nd set of pics looks awesome!!
Old Feb 12, 2003 | 10:06 PM
  #43
92camaro44's Avatar
the new mirrors look pretty good. Something you don't see on every camaro, so it stands out. nice install.
Old Feb 13, 2003 | 12:57 AM
  #44
92camaro44: i guess i'm going to break it to you but thats a
trans am. just breaking your bal$$
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
roysatikas
Sep 22, 2015 08:15 PM
