Need for spraying silicon
Old Feb 19, 2003 | 02:43 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Just wanted to say that everyone should not to forget the importance of taking care of those weatherstripes. I took of the teetops opened up the hatch and sprayed everything rubber on the car. A testament to the benefit of silicon spray---all the squeeks totally went away. A regular schedule is now on my calendar.
Old Feb 19, 2003 | 05:01 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
Re: Need for spraying silicon
youre right it helps alot. it does come back though. and i get lazy and stop spraying it. but it certainly does work!
Old Feb 19, 2003 | 05:11 PM
dsaint1347's Avatar
What brand of silicon do you use, I am tired of those squeeks.
Old Feb 19, 2003 | 10:35 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
i dont know the brand, the can is in the car which is not here at my house right now. sorry.
any generic plain old liquid aerosol spray can of silicon will be perfect.
Old Feb 20, 2003 | 08:34 AM
MdFormula350's Avatar
yeah it does help, good tip!
Old Feb 20, 2003 | 11:48 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
brand name woul dbe nice to know
Old Feb 20, 2003 | 01:54 PM
Dont remember the name also. Hes right any brand will do the trick. The statement on the can says to use it for protectorant and lubrication qualities. Believe it or not a friend of mine uses Mr. Sheen furniture polish. I chose the more automotive application and got this can from the automotive supplier. Dont use Armoral.
Old Feb 20, 2003 | 04:07 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Ive used the silicone on my seals. The 1st time i did it, i used the whole can on just the t-tops, they just soaked it all up. it did seal pretty good after that.
Old Feb 21, 2003 | 10:53 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
yeah if its the first time, it takes alot, do it every week or so and it hsould keep them pretty good.
but again, brand name doesnt matter. cheapest you can find is best.
Old Feb 21, 2003 | 02:01 PM
Do they make this stuff in the paste form. At work we have something called silicon grease. Would that have the same effect? It is a food grade grease. I may try it on a small piece of rubber and find out. It would be very easy to apply and you could get a better coating.
Old Feb 21, 2003 | 03:12 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Just be sure you don't use it straight from the can. The aerosol propellant is harmful to the rubber itself and will dry it out just about as much as the silicon lubes it up. Over time, the rubber can deteriorate quicker than if you'd just keep them clean and dry. If you do use silicon out of an aerosol can, spray it on a rag and wipe it onto the rubber seals instead.
Old Feb 23, 2003 | 10:16 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
whoopsy! thanks for the tip bud, i guess next time ill spray the rag, not the rubber thanks again! i didnt know that.
Old Oct 21, 2003 | 09:31 AM
HamSpiced's Avatar
ttt
Anyone know of a Good silicon spray to use for the winter? Know if 3m makes one?
Old Oct 22, 2003 | 06:56 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I believe Gunk is the brand that I have.
Old Oct 22, 2003 | 11:07 AM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
I have used silicon grease, still squeaks I guess I will try more.
Old Oct 22, 2003 | 12:44 PM
bnoon's Avatar
Spray silicone isn't for getting rid of the squeaks, it's for conditioning the rubber seals so that they don't dry rot. Unless I'm misunderstanding you, you need to adjust your clips to stop T-top movement, or adjust the stops on your window travel to minimize rubbing... That's really the only way a T-top can "squeak"...
Old Oct 23, 2003 | 08:52 AM
HamSpiced's Avatar
Frame Flex....BUY SFC'S!!!!
Old Oct 23, 2003 | 09:24 AM
camaro05's Avatar
Car: 91 Z28
yeah, that would be the more expencive solution
Old Oct 23, 2003 | 06:04 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
For the ultimate in weatherstrip care, go to your nearest BMW dealership parts counter and buy a tube of Gummi Pfledge.
It comes in a tube w/ a foam applicator on the end. It works awesome.
Old Oct 25, 2003 | 12:44 AM
HamSpiced's Avatar
yea... cause ther are so many BMW dealers around here.....
Old Oct 25, 2003 | 08:02 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Don't be a dick, its just a suggestion.
Old Oct 26, 2003 | 02:20 PM
HamSpiced's Avatar
lol, im not being a dick, im serious... ive lived in detroit all my life and ive never seen one BMW dealership...
i know it was a suggestion, i ran a google search on the stuff and i couldnt find it anywhere...
ive seen countless posts of BMW forums wher epeople Gummi their **** all the time and then still love it but i cant find gummi anywhere..
A more helpfull post would be to mention gummi and a link of where I could obtain some
Old Oct 27, 2003 | 07:20 PM
dsaint1347's Avatar
You can say the word dick and get away with it?
Cool
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Oct 7, 2015 10:15 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
