Stupid Hood...
Old Feb 20, 2003 | 02:11 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Stupid Hood...
I searched, didn`t find it, but I`m SURE I read it somewhere...anyways, brought the car out now that the weathersà bit better, and found since the last time I put the hood back on, the hood release fails to work...it`s attatched (the wire to the lever), but it just isn`t ùnhinging`it, I guess. I mean, it releases the hood slightly, enough that I have to push it back down to click it closed, but not enough to open it. What causes this, and how can it be fixed..É I just need to pop it up once to re-align it (again... ) in the Spring. Thanks.
Old Feb 20, 2003 | 04:07 PM
Azure's Avatar
*****Bump*******
C'mon, help a guy out here...
Old Feb 20, 2003 | 04:13 PM
Azure's Avatar
nevermind, better search criteria = answer.
Old Feb 20, 2003 | 05:28 PM
Redliner's Avatar
Car: Tahoe
I did not take my hood off but I did have it on stands for a while and that made the hood not ever want to come up
Jack the car up in right in front of the doors and that might do it
It pulls the hood back and make everything nice and loose
now I have no problems
Old Feb 20, 2003 | 05:30 PM
Azure's Avatar
All's good, I crawled under (in the snow), f00ked with the release mechanism, and 'sprroing' it popped up. Lubed everything, extended the spring, I'm golden now.
Old Feb 21, 2003 | 09:33 AM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
silly canadians............................j/k
btw like the avatar did you do that yourself?
Old Feb 21, 2003 | 12:02 PM
Azure's Avatar
Nope, can't take credit for it...someone from the Ontario Regional board made it, though their name currently escapes me...
Old Feb 21, 2003 | 09:34 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
mine does the same thing...its a pain in the butt, i thought it was cause my hood struts are bad and made it have to much weight..guess im wrong
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
