4th gen steering wheel
Old Mar 2, 2003 | 01:13 AM
irocz4life's Avatar
i have an 88 iroc-z and i want to put a 4th gen steering wheel in it, is this going to be simple? or is there any problems i may run into or anything that i need to buy to make it work?
Old Mar 2, 2003 | 04:17 PM
Grants85TA's Avatar
Bolts right on in. I put one in from a 96 T/A .
Old Aug 16, 2004 | 12:00 AM
Cuno's Avatar
I have a 4th gen steering wheel...the splines are different than my stock steering column though...the steering wheel has 2 flat areas that the column does not have. Has anyone else had this problem or is there a way to fix it?
My car is a 1985 Z28
Old Aug 16, 2004 | 10:57 AM
Grants85TA's Avatar
Air bag steering column would be the easiest way. They have the flat spaces you describe. Or modify your present steering column.
Old Aug 17, 2004 | 05:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I put a 4th gen Camaro wheel on my 86 Trans Am column and it went on just fine.
Old Aug 17, 2004 | 11:01 PM
Cuno's Avatar
ok...the flat spots did not seem to be for anything...I bolted the wheel on and it went on fine and works correctly...
Old Aug 17, 2004 | 11:18 PM
craashmann's Avatar
Car: 1991 Camaro Z28
Isn't that a 3rd gen 90-92 steering wheel?
Old Aug 18, 2004 | 01:52 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
That is identical to my dash with my '91 RS steering wheel. Those flat spots concerned me too at first, and they do have a purpose. They correctly line the steering wheel up on the shaft like a little key-way. When I installed mine, I just put the bolt on and tightened it and the wheel slid right on. I made sure I had the wheels perfectly straight and the steering wheel as close to center as possible before torquing on the wrench. A few splines on the shaft probably got ground flat, but hey, it worked!
Old Aug 19, 2004 | 08:33 AM
Cuno's Avatar
Hmm...guess it is. I thought it was a 4th gen...oops!
Old Aug 19, 2004 | 11:38 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
yep it is a 90-92 camaro steering wheel and man the horn is so hard to push. you might want to try the horn before you need to use it to see how hard you have to push it. but man it looks really good with whe older gauges.
Old Aug 19, 2004 | 11:57 AM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
4th gen wheels are UGLY ina 3rd gen, just go grant.
Old Aug 19, 2004 | 02:38 PM
Car: 1997 S10
i like the 4th gen wheels the horn is alot easer to use. its just persional choice i think what zepher did looks great.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
