Anyone have roof flex problems?
Old Mar 9, 2003 | 11:29 AM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
Ok, most of you know my car isnt stock, right. Well it runs mid 13's in the right temp. ok, wel when my dad owned the car, he noticed about a 1" tear in the roof right behind the right side window, you know at the top back corner. He welded it together, grinded alittle, welded again, grinded, sanded, then painted it. My question to you is if anyone has had this happen to you before. I talked to a buddy in an auto repair shop, and he said he sees our cars come in all the time with heavy mods done to the car and they accually put dents in the pilliars and rear roof supports! The really weird thing is I have thick steel wall seamless faberacated sfc's. I have noticed that the tear is comming back too! Anyone happen to? Any suggestions? I have two pictures with the tear not focused in very well, just look for what im talking about.
Old Mar 9, 2003 | 11:32 AM
Camar92's Avatar
Car: 1986 IROC-Z
Axle/Gears: Stock
Here is photo number two, you can see better in this photo. Its in the top left hand corner of picture.
Old Mar 9, 2003 | 01:30 PM
Tonyrodz's Avatar
Transmission: auto
My old Formula had the same problem. When I was parting out the car I noticed a huge rip on the driver side floor board behind the driver seat. I also had the same tear as you're talking about.
BTW-it was an 89 Formula w/350 tpi--these cars have alot of torque stock-so just imagine a few of the right mods!!:O
Old Mar 9, 2003 | 01:31 PM
Tonyrodz's Avatar
Transmission: auto
another
Old Mar 9, 2003 | 01:33 PM
Tonyrodz's Avatar
Transmission: auto
This is the crack in the floor I was talking about.
Old Mar 9, 2003 | 05:28 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Thats exactly why our cars should have come stock with subframe connectors :P
Old Mar 10, 2003 | 08:52 PM
MdFormula350's Avatar
i agree!
Old Mar 10, 2003 | 09:51 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
my TA had inch long cracks in the same spot on the roof, ground down, welded then repainted...they came back a few monthes later, this is with only the LG4 motor...shows how well the unibody design works huh?
Old Mar 10, 2003 | 10:59 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
All thirdgen Fbody's should have had a full frame for G0D's sake. GM Technicians
Old Mar 11, 2003 | 10:24 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I had th same problem with my 84 Z28 (L69).....from factory, they used a lead filler to attach the quater panel....sail panel...to the roof. The lead eventually gets weak and tears.....and has a break in the body. This is what I had to do..........I had to grind out all of the lead.....then...weld in a new piece of metal...added a lil body filler...and it was good as new. It was fine...and still would have been fine.....but...since I was hit....it cracked..and the car is totaled....
New2Chevy
Sep 28, 2015 12:35 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
