how do you fix lip on console?
Old Mar 12, 2003 | 12:58 PM
joshp14's Avatar
ok, how do you fix this properly? i tried fixing it once with some contact cement and it worked for about 2 weeks, then it started to come undone. When i fixed it i glued the lip (red arrow) to the plastic edge (yellow arrow). this was the best way that i thought it could be fixed....obviously i was wrong.
anyone have any suggestions?
joshp14's Avatar
guess it helps if i attatch the pic...
Old Mar 12, 2003 | 04:07 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
that happened to mine too
Old Mar 12, 2003 | 04:23 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
dont fool around with anything but ... SUPERGLUE.
it really works great there.
Old Mar 12, 2003 | 05:26 PM
joshp14's Avatar
so did i glue together the right things? do i glue that lip to the plastic piece? cuz the lip is only like 1/8" or 3/16" wide.
Old Mar 13, 2003 | 11:32 AM
Diggler86's Avatar
Car: 86 TA
yeah thats correct, probably your glue just did not hold up.
i think the vinyl actually likes to shrink which creates the problem.
Old Mar 13, 2003 | 07:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You guys are playing with glue? Use steel! You can see what I did in this pic... it's when my ignition lock broke. I did this fix a few years ago (like, '96), and most of the paint is missing off the bolt heads. The bolt heads were primed and painted gloss black, and the braces themselves were primed and painted with "wrinkle black". The brace is 1/8" thick, 1/2" wide steel stock from Home Depot.
It worked out really sweet when I installed my B&M shifter- the B&M shifter paint is painted with wrinkle black!
Old Mar 13, 2003 | 09:05 PM
firebird13's Avatar
Yea tomb i got the same thing as you do..the strip of steel but i need to re-do it...Im getting pics of my car up tomorrow.for sure..ill post one when i do!
gta892000
Aug 11, 2019 11:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
