Leather auto shift knob...????
Old Apr 13, 2003 | 12:42 AM
CaysE's Avatar
Leather auto shift ****...????
I bought this shift **** for my car, thinking it would fit without a problem Well, as it turns out, it doesn't. My car has the round black cue-ball looking shifter **** on it, which seems to mount differently than what I just bought. Is there a way to fit the leather **** onto my car??? Is it possible to get a different shaft to mount the **** on?
Please offer whatever help you can, I definitely want to install this ****!
Old Apr 13, 2003 | 01:21 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
You have to get a shifter out of an 88-92 Camaro. I know because when I actually find that 87 IROC-Z (been looking so long) I'm changing it to the round **** because I just don't like the square too much and I already went and got the shifter, ****, and everything in advance.
Old Apr 13, 2003 | 02:38 AM
CaysE's Avatar
LOL... maybe you can send me the shifter when you get the car
Old Apr 13, 2003 | 03:46 AM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I have a shifter from an 88 pm me your address and you can have it.
Old Apr 13, 2003 | 04:42 AM
Administrator
LOL, who knows when that'll be. Besides I gotta save it for originality.
Old Apr 14, 2003 | 06:52 PM
cdoyle's Avatar
It can be done.
My 84 had the ugly plastic round **** thing too.
You have to do some modifying to make it fit, If I remember right.
Coming out of the shifter is a plastic stick like thing right? This has to be trimmed off some, because its too long with the new style ****.
You'll also have to use a dremmel, and cut out some slots down the front and back of the shifter to allow the **** to slide down onto it.
It takes a little patience, and some skill with a dremmel but you can make it work. Took about an hour or so, to make it fit the way it suppose too.
Mine has been on there for a couple years now, and doesn't fall off or anything.
Chris
Old Apr 14, 2003 | 07:06 PM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
i guess i got lucky on my 86 t/a with the t handle shifter i put in the 4th gen console and picked up a 99 camaro lether one like in your pic and it went right on the clip was a little tight to push on but no problem at all
Old Apr 14, 2003 | 09:18 PM
CaysE's Avatar
Chris.. how does the **** stay on? I don't see anywhere for a C-clip or other fastener like on the round *****.
I'm getting a shifter from Slow88lb9, but if that doesn't work out, I'll bust out the dremel.
Old Apr 14, 2003 | 10:10 PM
cdoyle's Avatar
On the front of the **** (or back depending on how your looking at it), the side toward the radio.
You'll see on the shifter ****, a very small slot where a U shaped pin goes through. Hopefully the pin is there, on the one you got. If not go to a wrecking yard and try and find one.
Pull it out of the ****, and place the shifter **** onto the shifter. I was able to now tap the pin back into the ****, which then fastens itself around the shifter itself. Which holds it in place.
The factory shifter for those cars, had a small slot for the pin. I can't remember if I needed to or not, but you may need to take a cutting wheel from your dremmel, and make some very small cuts on the shifter where the pin would slide onto it. Sort of a channel to help the pin slide onto the shaft.
Its really not that hard, its harder trying to describe the process.
Old Apr 14, 2003 | 11:38 PM
CaysE's Avatar
OK, I see what you're talking about. The **** didn't come with a pin, but maybe there's one on the shifter that's being sent to me. If not, I'll hunt one down. Thanks for the description
Old Apr 28, 2003 | 09:39 PM
CaysE's Avatar
Does anyone have a part number on the pin that holds the **** in place? I'm not having any luck
Old Apr 29, 2003 | 08:24 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
10028352
Old Apr 29, 2003 | 10:34 PM
CaysE's Avatar
Thanks a lot, Slow88lb9, you've been a tremendous help. PM me your address so I can send you some cash for shipping out the shifter to me. It shifts a little funny, but nothing 5 minutes and a dremel won't fix. Where do you get the part numbers from?
Old Apr 30, 2003 | 01:31 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Hay bro don't worry about the the money $5.00 wont break me lol.I bought one of those camaro cd's with all the part numbers and illustrations on it.
That was money well spent.
Old Apr 30, 2003 | 02:49 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
where did ya get that from, and how much did it cost ya?
Old Apr 30, 2003 | 03:57 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
http://www.metzcon.com/fbodymanual/
Old Dec 17, 2003 | 08:18 PM
CaysE's Avatar
Originally posted by Slow88lb9
10028352
Does anyone in northern NJ have one of these? There's no way I'm spending 20 bucks for a pack of ten to get shipped to me. GMPD sucks...
Old Dec 22, 2003 | 12:30 AM
CaysE's Avatar
ttt
Old Dec 23, 2003 | 07:39 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I got the same thing. clip was kinda tight, but it went all the way in.
I like the Camaro ***** better too.
Old Dec 23, 2003 | 11:46 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
off topic
Hey Zepher nice video page but whats up with the Leann Rimes vids? Also its cool to see people helping eachother on here. Theirs been too much arguing going around
Old Dec 23, 2003 | 11:52 PM
Zepher's Avatar
Re: off topic
Thanks,
I made a LeAnn Rimes compilation video a few years back and was giving them away free with the purchase of my photo set.
Her lawyers didn't like that so after getting several letters from them, I stopped selling the photoset.
Those vids were the opening and closing of the video. I did them with Lighwave 3D, Speed Razor, and The Video Toaster back in 96/97.
Old Dec 23, 2003 | 11:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Why not just change the whole shifter out instead of trying to modify the old one?
I did!! $5.00 and 15 minutes work.
The Trickster!!!!!!!!!!!!
F-body driver
Mar 6, 2023 11:44 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
punkmaster98
Sep 8, 2015 09:45 PM
scottmoyer
Sep 7, 2015 07:06 PM
