Mirros wiggle
Old Apr 13, 2003 | 08:14 AM
HimR6's Avatar
Mirros wiggle
when i am driving down the raod my mirrors wiggle not the whole thang just the glass it is hard to see out of so any help would sure be useful thanks
Old Apr 13, 2003 | 08:30 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
depends on how it wiggles.. the glass section is held on to the plastic mirror retainer via adhesive strips.. these could be letting go, if they do.. well there goes your mirror.. it happened to one of mine.
if this is the problem you should be able to pry the mirror off the plastic backing plate (carefully) then clean the backing plate and cut a bunch of 3m double sided foam tape or similar and use it to put the mirror back on..
Old Apr 13, 2003 | 10:52 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
If the glass is secure to the plastic it's stuck to, there are 3 Phillips head screw that hold the plastic "movable" assembly into the metal outer assembly. You can access the screws by adjusting the mirror. Make sure those are tight.
HTH!
gta892000
Aug 11, 2019 11:16 AM
Elephantismo
Feb 13, 2019 12:51 AM
gta892000
Sep 16, 2015 12:37 AM
lakeffect2
Sep 7, 2015 03:52 PM
89 formula TPI
Sep 7, 2015 10:19 AM
