Need a new door handle
Engine: slowtacular L03 305
Transmission: slushem 700r4
The little metal wire on the under side of the handle on the drivers side was hanging down the other day. I then went to see if i could fix it, well no. The metal clips that are molded into the handle had broken so now i need a new one and maybe some help on how to install it. So were should i go for one and whats involved in changing it? I will be going home this weekend so i know i can grab one off of a yard pretty easy depending on whats involved.
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
get different handles altogether i beleave it is deadbird that has different handles he could tell you how to do the mod trust me in the end it looks really cool and well personally i hate the sqaure door handles that we've got now.
I'm not looking for a custom bit that requires body work, i just want to replace the one handle. I know that third gen resource has em used for $10 so ill probably get em through there, but now i am just wondering what exactly is involved in changing it.
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Check out the HELP section in your local part stores. They have them for around $20 ea. Foriegn stuff though.
Yep, they are carried on the shelf in the HELP sections around here as well. I've had to replace one for exactly the reason you described. It would have been nice to go with a new OEM piece instead of what is more than likely inferior, but you can't beat the price and convinience. Never had any problems with the new one.
but when you take off the panel be careful not to pull out the little white plastic i don't know what they are called but they hold the panel onto the door if you rip those off/out and break them you'll have to go but replacements or your door panel won't go back on right.
I know, i have taken door panels off of a few 90's GM cars and out of my old bmw and those little plastic bits are not fun. They'll brake just because they want to.
I always use two small putty knives to take the door panels off. I slide them up to either side of the plastic retainers or whatever they are called and twist them to pry it out of the door.
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
