regular camaro conversion
Old May 22, 2003 | 09:48 AM
Kaas's Avatar
Car: 89 Iroc-Z
how hard would it be to turn a reg. V8 camaro into a z-28/iroc, putting on all the ground effects and bumper covers and such.
Old May 22, 2003 | 10:18 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
depends if the car already has ground effects on it, etc.
If the car is bare, then you'll have to drill holes for the ground effects. You should be able to do it in a weekend.
Old May 22, 2003 | 10:30 AM
Kaas's Avatar
Car: 89 Iroc-Z
it does not have ground effects. what all was different from the regular camaro model and the z-28...i know of the ground effects and the engine/carb...is the tranny and the interior the same?
Old May 22, 2003 | 12:07 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
the z28s/irocs have different gauge clusters, better rear ends, better suspensions, better brakes, better wheels.
Old May 22, 2003 | 01:25 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You'll have to get the complete newer front bumper with headlamp bar, impact bar etc, drill some holes for the gfx pieces, bolt on the rear bumper, and weld on the side tabs that hold the gfx up. Heres a pic of them, see just below the door opening.
Old May 22, 2003 | 01:40 PM
Kaas's Avatar
Car: 89 Iroc-Z
so, if i was to want to make this camaro a z-28 clone, what would have to be done to the rear end besides the bumper cover? and also, everything interior wise will be able to just bolt in..correct? i have an 84 z that i will be using for parts if i was to buy this camaro, so i will have most of the things needed, except rear end (someone hit me in the rear) =( but, the one i am looking at is an 87...so, i was planning on just taking the interior out of my 84...possibly switching the tranny if it wasn't the t-5....then slap on some ground effects, front spoiler, new front bumper cover and rear bumper cover, then do the suspension and exhaust later.
Old May 22, 2003 | 02:41 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
The bumper cover just bolts on, you'd have to drill holes for the quarter ground effects, a hole just behind the door for the rockers, weld on the rocker mounts, drill 2 holes in each fender rear for the side skirts, drill holes in front of fender for front skirt and swap the whole bumper setup.
Old May 22, 2003 | 02:51 PM
Kaas's Avatar
Car: 89 Iroc-Z
awesome, thanks for all the help guys, still not sure if i am going to be buying this car, unless i get a great deal on it, i will be looking for another heh..if anyone knows anyone selling an 83-88 iroc/z-28 5 speed, be sure to let me know...lookin to spend around 3 grand for one that runs pretty good and doesn't need to much work done. e-mail is megaparanoid@yahoo.com
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
tmellott89
Aug 16, 2015 02:58 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
