shift knob removal?
Old Jun 1, 2003 | 09:03 PM
ceaser76's Avatar
shift **** removal?
Ive a 83 z28 auto. The shift **** has a messed up button that doesn't work. It seems to be stuck down. I want to see if I can fix it but I don't know how the shift **** comes off. It's aggrivating becuase in the 10 different cars I've had I've changed most.
Old Jun 1, 2003 | 09:21 PM
HaroGt14's Avatar
On my 91 there is a little pin infront of the shift **** that you have to pull out before the shifter will come out. It's towards the bottom.
Sean
Old Jun 1, 2003 | 09:26 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I'm not sure about the year models, but I know they (Chevy) used two different styles of shifters, Try HaroGt14's first, If that doesn't work, just pull the **** off the top, it'll come off with a little bit of effort, and there's a small snapring around the base, get that out, and you'll be knobless so you can fix your troubles.
Jeremy
Old Jun 2, 2003 | 08:33 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
yeah, just pull the button off and then you will see a little clip on the base. Its a little tricky to get it off but once you get it thats it.
Mike
Old Jun 2, 2003 | 10:19 AM
deadtrend1's Avatar
be careful not to punch your face like i did, you have to look straight down into the **** from the top once you pull the dentent button out. Spread a little u-ring with a screw driver and it comes off.
Old Jun 2, 2003 | 02:44 PM
CaysE's Avatar
LOL... come on guys, just get the tool for it, it's all of 5 bucks at Sears, and takes literally seconds to take off those C rings.
The tool looks like a small wrench, except it has a tapered point on each side, to insert into the holes at each end of the C ring. Squeeze the handle and the ring will widen. Simple!
As far as the 83 shift ****, unless you're willing to break something, you HAVE to take out the shift button first. Just pull hard, it will come out. The C ring is underneath it, inside the ****, and then the **** just slides upward.
If you can't get the button off and are willing to break something, you can push the **** down. Use a solid tube and a hammer if need be, to knock the **** down the shaft without hitting the button itself. Then get a new ****; the shaft will be fine.
Old Jun 3, 2003 | 12:17 AM
ceaser76's Avatar
I got it today. Thanks for the info. Didn't know the button popped off so easy
Old Jun 3, 2003 | 12:25 AM
ceaser76's Avatar
1992 Trans Am
May 10, 2023 07:19 PM
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
