90-92 dash in an 86.
I'm doing an lt1 swap and need to switch my speedo over to vss instead of cable. The guages are different so i need to swap the whole cluster. Will it fit correctly, or are the clusters different sizes. I'll be ok if the wiring is different as long as it will fit in right.
Wont fit. If you want to leave the stock dash in, you can make yourself a cluster using aftermarket guages, but the 90-92 cluster wont bolt in. Or if you want to replace the dash you could do the 90-92 dash with 90-92 cluster, or even a 4th gen dash with 4th gen cluster. Up to you.
Car: 85 Z
Engine: 383
You mean this......
Here is a link to what it took to do it hope this helps Ya!
https://www.thirdgen.org/techbb2/sho...hreadid=186037
Car: 85 Z
Engine: 383
Here you go this should tell you everything you need to know!
Good Luck!
Good Luck!
Car: 92 Z28
Engine: Boosted LSX
why not just swap in a complete 91-92 dash?
I have a spair shell layin around.
No harness in it though. and its a 110 speedo. Came outa my 91rs vert
Looks like you guys are talking about a Camaro for the swap. On my 86 T/A I'm still in the process of swapping in my 92 dash setup.
has the nicer layout for the switches and also has that padded bolster under the column.
Pic isn't my car.
Pic isn't my car.
