How hard is it to put in a 4th gen console?
Old Jun 21, 2003 | 04:02 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im not too fond of the 4th gen dash however my console is looking bad and I never really liked the square look, im thinking of hitting the bone yard and getting a 4th gen console, is it just a slap on project like seat? Thanks.
Old Jun 21, 2003 | 10:58 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Use da searchy, topic is brought up once every 3 days...........
Old Jun 22, 2003 | 11:45 AM
SgtSkip's Avatar
Do a search and you will find lots of niput. CustomX's dash looks awesome. I'd do it but I want to keep my HVAC.
Old Jun 24, 2003 | 08:15 PM
Tonyrodz's Avatar
Transmission: auto
In a Bird it's easy as pie, bolt in and go--in a Maro a little more involved but still easy. Just make sure you get one from a stick--autos won't work.
Attached Thumbnails How hard is it to put in a 4th gen console?-4th-gen-console-2
Old Jun 25, 2003 | 08:11 AM
confucius101's Avatar
why won't the auto's work?
I'm thinking about swapping a complete 4th gen interior
with my 91's and yes i have auto so what did i miss?????
Old Jun 25, 2003 | 08:29 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
The auto console from a 4th gen has the shifter 3" off from a third gen. That is why you will need to use an manual console.
Old Jun 25, 2003 | 08:59 AM
WOW ok thanks for the info
Old Jun 25, 2003 | 03:02 PM
pasky's Avatar
Works for me any hoot, my car is a manual.
Old Jun 25, 2003 | 03:37 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
OFF TO THE YARD I GO.:lala: :lala: :lala:
Old Jun 25, 2003 | 07:12 PM
War_Eagle's Avatar
My question on this topic is, do you have to modify the radio pod or will everyting work together?.......
Old Jun 25, 2003 | 07:14 PM
Tonyrodz's Avatar
Transmission: auto
Radio pod will work as is--no mods to it are needed.
Old Jun 25, 2003 | 11:17 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
does the console for a manual work if your car has an automatic?
Old Jun 26, 2003 | 12:19 AM
tbfirebird's Avatar
Engine: ??????????
yes hotrod87camaro
Old Jun 27, 2003 | 11:44 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Heres my question...is it possible to install a b&m megashifter with this console? I want a 4th gen consoul and a megashifter but I hear you cant use it with a 4th gen console.
Old Jun 27, 2003 | 12:47 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I attempted to try an Auto plate in my Formula the other day and it was no go, even with moving the shifter back, it was just too tall.
I then tried a 4th gen shifter and that still didn't work, this was too high and too long.
It seems like the 4th gen shifter sits lower on the 4th gen trans tunnel, or the console unit sits higher.
Old Jun 27, 2003 | 11:49 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
What about the mega shifter. I have one, but I want to do a 4th gen swap. Cant I just use the leather shift boot to cover up the mega shifter and make it look nice like that?
Old Jun 27, 2003 | 11:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you positive that it cant be done??
i was hoping to use the 4thgen shifter and console and just make new mounting holes
Old Jun 28, 2003 | 03:04 AM
Zepher's Avatar
I am pretty sure. I can take some pictures on Sunday of the way it sits and all.
I'll see if I can get pictures of a 4th gen automatic car and compare the two tunnels and mounting spaces/brackets.
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
sreZ28
Aug 14, 2015 07:48 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
