floorjacks ? which ones.. and where do they go
Old Jul 20, 2003 | 07:29 PM
lubranoc's Avatar
A friend of mine came over to help me with the new 92 firebird formula I just got. he brought his jack and jackstands. so instead of tearng the body up. I figured I would ask you guys .. WHERE does the jack and jack stands go ? also I should get my own, so what do you guys recomend ? I know its a silly question but I rather be safe than sorry.
THanks for the help
CHris
P.S. if you guys can show any pictures that be great.
Old Jul 20, 2003 | 11:59 PM
CaysE's Avatar
You can put the jacks in a number of places. Any of the crossmembers will do, as well as the rearend housing. You can also put them under the A-arms, and (obviously) under any part of the front or rear frame rails. I find the best jacking places are along my subframe connectors.
Old Jul 21, 2003 | 01:04 AM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Man... it isnt a silly questions at all, I have wondered the same.
These uni body car's kind of suck for jacking up if you dont have SFC.
My buddy totally f'd up his camaro when he jacked it up.
Old Jul 21, 2003 | 06:29 AM
lubranoc's Avatar
thank goodness
OK, I am glad other people have had these problems. I felt like such a jerk not knowing where to jack up my car. I want to jack up the front of my car to refurbish my calipers and change brake pads. so I guess the best place is the crossmember right behind the front wheels ? also any suggestion about what brand of jack and jackstands I should get ? I would hate for the car to drop on my face.
Chris
Old Jul 21, 2003 | 06:32 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I used an AC Delco low clearance jack. AC Delco also makes jack stants which are alright. But I prefer the ratcheting kind.
Old Jul 21, 2003 | 01:03 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Well if you have a big jack, itsbest to lift the whole front or rear of the car at the same time. So to lift the front, put the jack under the front cross member under the engine. (K member I think its called) For the rear the rear diff is a reall good place to lift the rear. On the rear, if you aren't removing the rearend the rear is a great place for the jack stands. For the front the jack stands can be placed right behind the wheels on the subframe rail. this rail will hold the car. you will want a jack stand that will cup the rail completly if possible. I don't really have any suggestions on brands, Your major concern with the jack, is that it will fit under the car, and that its got the reache to go from the front of the car to the cross member. Sears has a good one, but its$$$ look to pay 150+ for a jack that has the reach. As for jack stands, PM ones are cheap and I have never had a problem with them.
Only if its absolutly necissary lift one corner at a time, a few inches at a time. going back and forth. Don't go to high, you will twist the frame. If you are just doing brakes you can lift under the a arm, the body will hardly move but the tire will lift off the ground.
Old Jul 21, 2003 | 02:24 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
Re: thank goodness
Chris
I used the a-arms when I changed my struts. The car wiggles a little, but thats because the springs are taking some weight and cans till move. It doesn't wobble or anyhting, but if you push down on the fender it goes down a little and pops back up.
Now where do you jack the rear end at? edit: if you need to take stuff off. I can't think of what stuff right now, i'm a bit whipped from being out all day
Old Jul 22, 2003 | 09:29 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
u guys ever notice popping noises when you jack your car? sometimes ill hear a pop/bang from somewhere if i get one side much higher then the other.
Old Jul 22, 2003 | 02:42 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I jack my car up on the frame,
Old Jul 22, 2003 | 04:26 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I jack up the front via the engine k-member... the rear from the center of the diff housing. I put jack stands under the subframes
Old Jul 22, 2003 | 04:48 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
So do I, just like the photo. Zeph tough to get rolling without a driveshaft eh!
slow_90firebird
Dec 26, 2007 11:24 PM
steve's Z28
Sep 17, 2006 07:06 PM
Twowheelpeel
Nov 9, 2005 11:39 AM
85berlinetta2.8
Apr 21, 2005 07:17 PM
