Front quarter panels
Old Aug 15, 2003 | 08:02 AM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Is there or is there not a difference in front quarter panels between an 89 RS, 89 Iroc, and 89 Convertible?
Old Aug 15, 2003 | 09:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Known to the rest of the world as fenders, and no... they are all the same.
Old Aug 15, 2003 | 11:24 AM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
I think the copnvertable ones are different.. they have some sort of bracket underneath or something to that nature. I remeber a thread about it a while back
Old Aug 15, 2003 | 04:41 PM
CHCKLS's Avatar
Engine: 409 SR
I don't recall asking what else they were known as.
Anyways....
Anyone else know for sure?...
Old Aug 15, 2003 | 11:42 PM
Jim85IROC's Avatar
I'm telling you for sure. There's absolutely no difference at all in ANY 82-92 camaro fender except for the holes that the ground effect studs go through, but since all 89 cars used the same ground effects, that's not an issue.
There is certainly NO difference in convertable fenders. Convertables started out as t-top cars and absolutely no modifications were made to the front fenders.
I don't recall a car ever having a front 1/4 panel, so if you don't want to accept a little constructive criticism, make sure you don't deserve it.
Old Aug 16, 2003 | 12:21 AM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Front Quarter Panel's
Poor thang
:lala:
Old Aug 16, 2003 | 08:39 AM
MikeC.86Roc's Avatar
I hate to say it Jim, but that is definately not true...
I am afraid that I am a victim of this exact question at the moment.
I purchased 2 vert fenders for my 88 Iroc thinking that they would just bolt up. NO WAY... The rear mounts are COMPLETELY MISSING..
Jim is right here about the cars being the same, the vert's were actually an "afterthought" modification on the line during production so to speak. BUT.. They have a large bracket that bolts the fender to the chassis because the X-brace gets in the way of a normal fender! The vert fenders actually look like they have been chopped off on the inside and are missing part of the fender! If you are considering buying a set of vert fenders for a non-vert, DO NOT DO IT..
Here is a link to some pics that show just why the fenders just simply don't work. It's not even close!
http://www.geocities.com/mikecarter1234/fenders
Old Aug 16, 2003 | 01:51 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
IIRC the Vert fenders rear bottom attach to the aftermarket subframes or somekind of brace under there. Or they clear something to fit properly.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Street Lethal
Aug 14, 2015 08:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
