window squeegie strip?
Old Oct 29, 2003 | 07:57 PM
grndmasnightmar
Guest
Posts: n/a
how do you remove that stupid squeegie thing on the bottom of the window. you know that black strip that rubs against your window when you bring it up or down. mine is all dry rotted and i need to replace it.
Old Oct 29, 2003 | 08:13 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Gotta remove the door panel, loosen the 2 10mm bolts that hold the window against the outter belt moulding so you can gain access to the 2- 7mm bolts in the center of the door. Just a matter of removing these 7mm bolts and taking it off, then reinstall in reverse.
Old Oct 29, 2003 | 08:34 PM
grndmasnightmar
Guest
Posts: n/a
so that strip is attached by two bolts in the door?
Old Oct 29, 2003 | 08:59 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
not necessarily ..depends on which one..the one inside is held onto the back of the door pannel by staples and rivets
Old Oct 29, 2003 | 09:47 PM
IHI's Avatar
IHI
Re: ???
Alright, mine was an 86 bird so yours may be different. Once you remove the door panel there are 2 L brackets that force the window out against the belt moulding, you must loosen these 2 bolts so the window is allowed to be pulled in away from the belt moulding-this will allow you to gain access to the 5-7? 7mm bolts that attach the belt moulding to the door itself. Twas the case with my 86 bird.
Old Oct 30, 2003 | 09:15 AM
grndmasnightmar
Guest
Posts: n/a
alright
ill have to give it alook one of these days. and while im on the topic the black strip that goes along the door and lips over onto the the door a little. right below that window squeegie thing ...is that the same part or is it removed seperately and if so how?
Thanks again guys
Old Oct 30, 2003 | 09:34 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
same part...its attached to the body pannel for the inside of the door
Old Oct 30, 2003 | 09:56 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Mine was 5 phillips head screws that I had to use an L-shaped screwdriver to get in the channel to remove them. Need to remove this also when having you car painted.
Old Oct 30, 2003 | 10:54 AM
slinkh's Avatar
Mine had 4 or 5 phillips head screws as well
Old Oct 30, 2003 | 11:32 AM
grndmasnightmar
Guest
Posts: n/a
cool
thanks:lala:
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Fireslash
Apr 11, 2016 06:43 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
kkirch15
Sep 30, 2015 04:44 PM
