replacement carpet
Car: 89' IROCZ
Engine: 5.7 L98
replacement carpet
I'm planning on replacing the carpet in my 89'iroc. What is the best brand? I would like it to have the same 3 wear pads as the original, dead pedal, heel pad and to the right of the gas pedal. Also where would I get it? Online vendors would be preferred.
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
Re: replacement carpet
Moderator/TGO Supporter
Car: 1997 Z28
I too am about to order new carpet, and would like any suggestions or ideas.
Also, has any ordered the new door panels from hawks? I was considering ordering.
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
ACC is an excellent company to deal with. better then my stock replacement. i believe you can get it through jc whitney and save even more money rather then ordering direct like i did.
here is what it looked like when it was new..
that worked well....
this is what it looked like right out of the box. you are suppose to let it sit in the sun so that it becomes flatter. i just used a heat gun on some areas and it went it very well. had to open up the shifter area slightly and shave some off the sides by the doors. beyond that it went very well.
Car: 87 IROC
Engine: mini-rammed 350
Got my carpet from 1A auto.com,it was an ACC carpet,it went in very nicely,just becareful trimming around console,do it slowly,make sure carpet is far enough forward
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
ACC
Here's another vote for ACC, i just helped a friend put some in his 89 GTA. It's really high quality and fit perfect. The only thing is make sure it's warm out when you do it, or else have a hair dryer or heat gun, otherwise it's real tough to work with when cold.
Car: Black 1984 Chevrolet Camaro Z28
Engine: LG4 305
Car: 89' IROCZ
Engine: 5.7 L98
I ordered my carpet from A1 auto on ebay. It was the best deal I could find $129.95. It was ACC carpet and they even sent me samples so I could get the color right. I went in very well even though I did it in the winter and it was cold in my garage. Taking everything out of the car and getting it back in was the hardest part. Overall I am very happy with the process and the result.
Car: 89 RS
Engine: 383 in building process
Gotta say that ACC has had an OEM mold fit for me. It's true what some others have said about slightly opening up the shifter area & also trimming the edges by the doors, but the mold itself was dead on for my car. And what fun would it be without some bumps along the way with putting it in.
But that's just me
But that's just me
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I got mine for 119 from summit raceing same color match i havent taken it out of the box yet tho its been sitting in my room for a year. IT came with the jupiter and such on it.
Car: 88 Camaro
Engine: L98 350
Originally posted by Red91CamaroRS
Does ACC's carpet come with the padding attached?
Engine: modded 5.0
Car: 1989 Firebird
Engine: 5.7 LS1
I second 1aauto.com thats where my carpet came form. They had it on ebay for I think I payed like 200 for it, if you go straight through their site its like 250 or so. They also sell matching trim carpet and floor mats. It is ACC carpet.
It has the factory style jute padding glued to the carpet also.
GRRR- LOL
I'm trying to remove as much weight as possible, while keeping the factory look. Obviously the padding doesn't weigh too much, but I'd like to get it without the padding underneath.
Car: 91RS
Engine: 305tbi
Originally posted by Gumby
Interesting.
I dug around and right now the best deal on Ebay is $119.00 + $20 shipping.
Item number: 2456133083
Interesting.
Car: 89' IROCZ
Engine: 5.7 L98
I didn't check it on a scale but the ACC carpet with padding was lighter than the stock carpet. I would guess about 5 lbs. I have not run the car yet, so it might be louder.
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
What about all the horror stories with ACC carpet? I've heard it fits good, but fades quickly. I touched on the subject a while back...
Here was what I found:
https://www.thirdgen.org/techbb2/sho...et+replacement
Engine: modded 5.0
I bought their carpet when I switched my interior from camel tan to black about a year ago. So far the carpet has not faded the least bit. In fact, I've already been through 3 sets of black floor mats b/c they fade so quickly and look grey compared to the carpet.
Car: 1989 Firebird
Engine: 5.7 LS1
Mine is still good after almost a year of it being in my car, I had it for almost 8mo before I installed it. Is it possible that the people that has had bad luck with it used something harsh to clean it with, or had t-top leaks or something. But my car is parked in the sun most of the time here in GA, and its yet to fade.
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
3 years, maybe 10k miles and car stored in the shade. Time to replace my horribly faded ACC carpet.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
iv heard MANY complaints about ACC carpet on the mailing list.
one of my friends orderd some of the car motorsports stuff and it was pretty well built stuff. a bit more spendy but iv heard more positive stuff about it than i have about ACC.
the car motorsports stuff laid in good and was molded about as close as you could get.
Not thirdgen related but I ordered ACC carpet for my 67 Mustang (which was a nylon loop carpet, very diff than our carpet) and it faded like no ones business over 2 years time. The black turned to a tan/purple color in places.
From what I gathered from the message board I was on at the time, this was typical of any classic mustang replacement carpet so it may not be just ACC but the design of the carpet. After I bought my carpet, they came out with a molded carpet with the new soft style which is what I really wanted. The crap that came factory felt like berber carpet.
BUT I do have a brand new set of ACC black carpet sitting in my spare bedroom waiting to be installed so I'll post back when I get it installed. For now, it's a playground for my sugar gliders...
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
My 89 T/A had ACC carpet in when I bought it, its green and faded. its freakin horrible. I have personally seen three different cars that this has happened to. Is there anyone else that makes carpet for our cars? I really don't want to give this ****ty company money for carpet thats gonna fade. its ****ing ridiculous. there is no excuse for it.
Car: 1983 Daytona Trans Am
Engine: LG4
I ordered from ACC for my '90 RS... The first time I installed it I ended up with a bunch of wrinkles... Last week in my upholstery class I re-installed it but I removed the padding which came with it and it fit perfectly!
ambainb
Apr 25, 2016 09:21 PM
