Custom Triple guage pod....Done!
Old Dec 2, 2003 | 11:39 AM
AC's Avatar
AC
Car: Used to drive a camaro
I'm done. I finished my guage pod. I designed it to look like it belongs there. It holds (3) 2-1/16 guages and uses the underdash light hole for wires so no drilling to hide wires/vacuum tubes. It's matte black styrene (similiar to dash material) and cost me 60 bux for the first one. I can hopefully get them cheaper if the interest is there. Let me know what you think of it.
Old Dec 2, 2003 | 11:41 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
that looks awsome, how did you make it, or did you buy it and just cut the holes in it ?
Old Dec 2, 2003 | 11:44 AM
nolanr0413's Avatar
Car: Trans am
that does look real good, good work , lets here more about that.
Old Dec 2, 2003 | 11:45 AM
AC's Avatar
AC
I designed it. I forgot to mention I used (3) autometer angle rings also, so I didnt' design those parts obviously. I didn't assemble it though, the bottom of the pod is actually heat bent and then it's all bonded together (3) pieces, front, top and bent cover with a ss240 bonding agent.
Old Dec 2, 2003 | 02:38 PM
FLYNLOW92rs's Avatar
Yup, I'm interested, show some more pictures.....
Is there any way we can order one?
Old Dec 2, 2003 | 06:40 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Thats the same place I got my 3 Pod Mounted, I got the black panel w/ white face guage kit from Sun. Looks real nice. I didnt want the chrome so I had to go with smaller guages, But I like how it looks, I'll see if I can get some pics!
Old Dec 2, 2003 | 06:52 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
too bad that's where my tach sits...
Old Dec 2, 2003 | 07:03 PM
SLOWFIVEOH's Avatar
Engine: 355
My 5 inch with shift light is mounted in front of my cigarette lighter next to the 3 pod
Old Dec 2, 2003 | 07:42 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Are those hard to see? It sure looks like they are...What do they control? Temp or something? Do they light up at night? If so what color? Like to hear more info.
nate
Old Dec 2, 2003 | 08:30 PM
AC's Avatar
AC
My guages aren't hard to see. I was going to use Autometers 3 guage mounting face BUT you would be able to see everything if I used that, so I designed and manufactured my own closure. My guages are oil pressure, air fuel ratio and boost pressure (for my P1SC). They guages sit on autometers angle rings and are just right so if I just glance above my stereo I see the faces fine. The picture makes them look like there hard to see because I used a flash....they're phantom guages and light up with the red bulb booty...
Old Dec 2, 2003 | 08:34 PM
AC's Avatar
AC
One more thing...I'm in the process of designing more 2 and 3 guage closures for the center console. They would mount on the sides (carpet is there now) I'd design them so you would have remove a bit of carpet but I'd also make sure the design was able to be carpeted so you could match the "console pod" to your carpet color or keep it matte black.
Old Dec 2, 2003 | 09:17 PM
iroctpis's Avatar
nice
looks good, thats just what I would do if I weren't planning on some hood gauges and a jongbloed hood!!!
Old Dec 2, 2003 | 10:26 PM
mw66nova's Avatar
Engine: 7.0L
here's the way i did my guages....
Old Dec 2, 2003 | 10:47 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
You did a fairly good job man good work
Old Dec 28, 2003 | 12:47 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
mw66nova ,
what are those buttons underneath your stereo receiver? could you get a better pic?
Old Dec 29, 2003 | 03:26 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
how hard is it to wire it up through the dash cutting ect thnks looks good
Old Dec 29, 2003 | 05:47 PM
AC's Avatar
AC
any of my experiences with wiring I've never had to put holes in anything...except the a-pillar for my dual guage pod. For my dash guages I've used a really strong double sided tape from 3M. Never had any issues with it not sticking.
Old Dec 29, 2003 | 05:55 PM
mw66nova's Avatar
Engine: 7.0L
i have other pics, but that is a pretty good one that shows it all. i just totalled the car so...my next car will be done a little different. it wasn't that hard to do, just take your time.
Old Dec 29, 2003 | 06:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heh, i cant find the pics of my old car.... i have a custom 3 gauge thing there too... looks like it belongs there...
i did find my old recall tach though:
Old Dec 29, 2003 | 06:45 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Nice job guys. I thought that I would post a pic of how I have my gauges installed in my car also. The custom "radio delete" and shift console "ash tray delete" plates were made from 1/8" 6061-T6 aluminum plate:
Old Dec 29, 2003 | 06:56 PM
AC's Avatar
AC
MCM, I have to say that looks sweet man. Do you happen to still have drawings (plans)? I wouldn't mind making something like that up in plastic.
Old Dec 29, 2003 | 07:13 PM
Car: '82 Trans Am
Transmission: TH475
No I don't. I just used the original bezels as templates, and outlined them directly on to the aluminum plates.
Old Dec 30, 2003 | 01:34 AM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
MCM- No more E-brake? and what is that thing in the space where the brake goes?
Old Dec 30, 2003 | 03:03 AM
MdFormula350's Avatar
nice guage setups!
Old Dec 30, 2003 | 09:48 AM
Car: '82 Trans Am
Transmission: TH475
Yes, the complete parking brake system has been removed and what you see is the cigarette lighter socket which has been relocated to power up plug in accessories.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
