i got a 84z
Old Dec 14, 2003 | 01:35 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i got a 84z
how hard is it to put gfx from a 85 -92 on i dont really like my gfx i like the newer ones better. is this hard or expensive
Old Dec 14, 2003 | 05:20 AM
88txiroc's Avatar
Why do you want to put new GFX on? You just listed the car for sale............................
Old Dec 14, 2003 | 11:46 PM
jocww's Avatar
if i keep the car i want to add the ground effects. i just like the more aggressive style. of the newer cars.
Old Dec 15, 2003 | 11:44 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
replace rear bumper, rear 1/4 gfx, rocker panel gfx, door gfx, front bumper and front chin spoiler. rear bumper bolts right on, rear 1/4, rocker, and door gfx will need new holes drilled, front bumper bolts right on, front chin spoiler bolts right onto the front bumper, but needs new holes in fenders. if you go to thirdgen resource or hawks, it will cost you around $650 for everything. shop around and you can find cheaper. i got everything for my lt for like $250-300.
Old Dec 18, 2003 | 10:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Did the same thing w/my 84.Swapped everything from an 89 iroc.Except my the front bumper.I like the look of my 84 fr bumper better.So what i did was cut off my 84 fr spoiler just where it meets up with the fender line.then cut the 89 spoiler the same way.I used the 84 spoiler on the bumper part & the 89 spoiler(L&R)side from the fender line to wheel end.I had to split the 84 & widen it where i cut it off,insert a steel plate to hold the gap open,rivet the plate to the 84 poiler,this way the taper would match the width of the 89.The just fill in the gap with flexible bumper repair compound.I only did all this,because (1) the 84 spoiler attaches differently the bumper than the 85 up style does & (2)I wanted my car to still look like an 84 Z28
Old Dec 19, 2003 | 03:54 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
@84 1LE; Wow! That sounds like quite a feat! Do you have any pictures of your car? I'd be real interested to see how it turned out!
@jocww; As far as difficulty, I don't think it's too challenging, just some precise measurements and a few holes to be made; it's a very popular procedure, so there's a lot of experience on the board that could help in a jam
Old Dec 19, 2003 | 08:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
No problem,here they are.its 6pm in cali right now.so its dark if you want daytime pics.Let me know......
Old Dec 19, 2003 | 08:28 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Heres another shot.The front part is the 84 spoiler.You can just see the vents on the front of it.You can also see the parting line where the poiler was cut off & the fender section of the 89 spoiler.
Old Dec 19, 2003 | 08:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Heres a shot of the back(inside) of spoiler where the 2 types(years) meet.it also shows the steel plates that are riveted on,taken from under the radiator toward the driver side.You can also see a small peice of fiberglass cloth between the plates that i used w/the flexable bumper repair...
Old Dec 19, 2003 | 08:57 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Heres the same side at an angle.There are 2 plates.The one w/the arrow is the one that lines up & overlaps the 2 sections.Theres also a small screw on the underside of the spoiler ends where the 2 sections meet,it keeps the ends from flaring out,the plate is shaped/angled to follow the contours of the spoilers.It also keeps the 89 section from moving in too far,so the 2 section are flush on the outer side.The other plate is the one that keeps the 84 section tapered/spread out correctly to follow the taper of the 89 section.This is beacuse the 89 spoiler is closer to the ground that the 84(by at least 1.5in).So the 2 sections would never line up correctly at the bottom or for that matter the top.Also the rivets can be seen from this side.On the outer side they are covered w/ the bumper repair.The rest of the conversion is basically a simple swap.
Old Dec 19, 2003 | 09:14 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Finally here is a side shot,although its too dark now.
jb3829
Brakes
Jan 24, 2009 10:12 AM
Phyte
Aug 24, 2006 09:17 PM
JES84Z28
Apr 26, 2005 09:34 PM
alphaomega
May 30, 2002 11:03 PM
