dash
Old Jan 12, 2004 | 06:21 PM
91zconvt's Avatar
Car: 87 Iroc
dash
As some of you may now, last spring I swapped my camaro's dash out for one from a firebird. Well, I guess I liked it at the time, but right now I really miss my old dash. Anyways, I still have the full camaro dash and want to put it back in. Simple, a couple hours of unbolting and bolting back up. Problem is, I lost the two wire connectors that go to the back of the gauges (the plugs) because I cut the ones from the camaro off, and rigged up the firebird ones. Anyways, I don't want to go through the hassles of figguring out which wire does what and goes where, so I just want to be able to get the exact ones that should be in my car, so all the wires match up. Now, I have a '91 z28 vert with a 305 TPI and a 5 speed. Anyone have any idea what cars I should be looking in? Probably another '91 305 5 speed I'd guess.
Please, I really need someone who knows what they're talking about.....
Old Jan 12, 2004 | 08:00 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You should be able to get the harness plug from any 90-92 car. Autos generally have the 'upshift' light in them, just unused. The only variance I know of in prior years (aside from thr v6/v8 tach part) was the 'brake' light (and maybe seatbelt, don't remember) was located on different sides of the cluster.
Old Jan 12, 2004 | 08:05 PM
91zconvt's Avatar
Car: 87 Iroc
thanks...
So it doesn't matter what engine it has? I mean, all the tach/speedo wires would plug into the same place anyway? Basically, I just want the wire colors in my car to match up to the wires comming out of that harness when I ..."detatch" it from a car in the boneyard.
Old Jan 12, 2004 | 08:38 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The easiest to find that will bolt right in and plug up will be a 91-92 V6 car dash and harness from a 5 speed car, though some of the auto cars got a harness with both connectors, you can check for the clutch switch connector up in the drivers side by the pedals around in there, a 90 will have a different tail light connector, a tbi car one would work but you will need to do a little wire changing to remove the buffer box...
Old Jan 12, 2004 | 10:58 PM
deadbird's Avatar
Engine: TPI 305/ v6
Maybe I'm reading wrong but, he just needs the cluster harness plugs to replace the ones he chopped off when he put the 'bird cluster (w/dash) in, nothing else ?
Old Jan 13, 2004 | 12:37 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I usually dont like leaving hacked up wiring, so I figured i'd post what he can bolt in there to restore the car properly.
Old Jan 13, 2004 | 12:45 AM
deadbird's Avatar
Engine: TPI 305/ v6
I agree with you 100%, I'm the same way. I was just going off these key phrases (to me anyways)...
I still have the full camaro dash and want to put it back in.....I lost the two wire connectors that go to the back of the gauges (the plugs) because I cut the ones from the camaro off, and rigged up the firebird ones..... I just want to be able to get the exact ones that should be in my car, so all the wires match up
Old Jan 13, 2004 | 07:20 AM
91zconvt's Avatar
Car: 87 Iroc
That's why I want the exact plugs. I mean, if everything matches, the wires are just going to be soldered and electrical taped at the plugs, thats it. All the colors will be matching. It's not really hacked up
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
