People using factory cable with Mega Shifter....come in please
Old Jan 23, 2004 | 01:57 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
There are a few people on the boards that have installed their Mega Shifter using their factory cable....no need to crawl underneath the car or adjustment. I really haven't had much luck though searching to find out how this is possible. I was told to cut of the factory bracket from the shifter, cut the bracket off the Mega Shifter and bolt on the factory bracket. That dosen't sound bad at all. I just ordered my shifter last night...and won't be installing it for awhile....and would like to get a head start on what to expect. I know alot of guys think that the B&M is junk..and is poor quality...then some guys think it's really not that bad. The main thing I wanna focus on is making this shifter work without swapping cables. And I'm sure I'll have alot of problems with the wiring...so...does anyone know how to do this? Thanks fella's
Old Jan 23, 2004 | 02:44 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
swaping the cables is really easy, probably easier than using your stock and having it break later. Ill try and find where my dad drew a picture of how to wire it so i can tell u
Old Jan 23, 2004 | 02:53 PM
Engine: 5.7
people say that the stock cable breaks...but everyone I've talked to that have done so said that they've never had any problems with using their stock cable at all. I know I'm not cut out for changing the tranny cable...I wish it would work out with ease....I'm not a mechanic at all....don't know the first thing about it..
Old Jan 23, 2004 | 04:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I changed mine to use the stock cable and it hasn't broke yet. Been a good year of use of hard slamming gears.
Main thing I didn't like about the B&M was it wasn't included with my shifter. It really long and has to be looped. Another was I'm to lazy to put a new cable in.
I can take the trim piece off and take some pics of my cable setup with my digital camera it might be a week or so.
Old Jan 24, 2004 | 01:19 AM
Engine: 5.7
Man, that would be really awesome if you could do that for me....and if it's not to much trouble....I'm not in any hurry at all. Could you also explain how you did it when you post the
picture(s)?
Old Jan 24, 2004 | 07:43 AM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
I used the old shifter base plate...just grind off the rivets to take off...place B&M shifter on top and grind lip of old base plate to fit...very qiuck to do.....mount all to the 2 front existing base plate holes and attach back of B&M to base plate...I have a 1988 Formula 350 so this method allowed me to move 2 " ahead and 1" lower than std B&M setup...had to notch my cig. compartment but the cig. ashtray covers it........
13.93@99.32mph
Old Jan 24, 2004 | 09:42 AM
Engine: 5.7
that dosen't sound bad at all....is that what you other guys did?
Old Jan 25, 2004 | 12:44 PM
Engine: 5.7
ok...I got my Mega Shifter today....i took 3 pictures of it....what brackets are you guys talking about that will have to be cut off....and then put back on with the factory brackets?
Attached Thumbnails People using factory cable with Mega Shifter....come in please-shifter3.jpg
Old Jan 25, 2004 | 12:45 PM
Engine: 5.7
another
Attached Thumbnails People using factory cable with Mega Shifter....come in please-shifter2.jpg
Old Jan 25, 2004 | 12:46 PM
Engine: 5.7
last one..
Attached Thumbnails People using factory cable with Mega Shifter....come in please-shifter1.jpg
Old Jan 25, 2004 | 12:59 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Here is my cardomain with my install
http://www.cardomain.com/memberpage/443548/9
Using the stock shifter will work, But I wouldn't reccomend. There is a lot more to it than just putting on the new cable, The BM cable is different, different shifts, different distances between, different tranny brackets. And your BM cable is pretty high quality, My stock shifter a piece of junk. The only PITA about the BM is running the xtra long cable. Took me about 2 mins to figure it out.. Oh wow, lots of work there , I can't justify NOT using the BM cable. Crawl just under your drivers door, and look up. You need to remove 2 bolts from the bottom of the tranny pan. and disconnect the shift lever offa the tranny. Then pull the cable un thru. Put the new one down thru, put on the bracket (2 Bolts) put on the new lever. Adjust. Tighten. Done!
Old Jan 25, 2004 | 01:01 PM
Daishi's Avatar
And about this grinding business. The plate bolts right up on the rear, You drill two new holes just above where your old shifter was placed. Then bolt down.... Not sure what this grinding rivets is all about....
Old Jan 25, 2004 | 02:42 PM
Engine: 5.7
I know it's not hooked up in my car or anything...but how come it only clicks back 3 times? It said to remove a pin...which I did...and it's not clicking back anymore then 3 times...shouldn't it click 5...through- Reverse, Neutral, Drive, 1 and 2?...nevermind..I figured it out
Old Jan 25, 2004 | 03:52 PM
Transmission: 700R
Grinding of rivets is to take the old BASE plate off the old shifter. Place the B&M shifter on top of the old base plate and grind the lip of the old base plate where the B&M shifter "feet" come in contact..along sides of old base.Did this to keep the holding eyelet of GM cable in place. Connect GM cable to pin of B&M shifter. All I did was use the GM shift cable and its holder to Not use that 5ft cable supplied in the kit. The GM cable is exactly 1/2 in length. The geometry of the "pull" shift pattern is the same. Before I attempted this; I height gauged the height and length of each position of both shifters and they were the same.Its been installed this way for 2 years and shifts smoothly.You will have to do a final adjustment of the cable at the tranny attachment underneath the car but that has to be done regardless.
Old Jan 25, 2004 | 04:01 PM
Engine: 5.7
So you didn't have to grind anything off of the Mega Shifter base plate? Just the factory base plate?
Old Jan 25, 2004 | 04:06 PM
Transmission: 700R
I just had to grind off the B&M cable bracket holder as it would interfere with the GM cable holder. This way worked for me but I would suggest to look at both methods of install and do a mock up of the assembly. I was determined to use the GM cable so I went this way with my setup and it did take a bit longer for the fit as this setup was my own idea...
Old Jan 25, 2004 | 05:07 PM
chrissy's Avatar
If you are up to installing a Megashifter then you are up to changing the cable. Trust me it's the easiest part of the install. Good luck with things.
Old Jan 25, 2004 | 07:54 PM
Xceleratemaro's Avatar
i have one in my camaro.. not happy with it as for street racing! dont get me wrong/ the shifter works good and looks good, but you cant just put it in 1st when ever you want.. to much slamming. im going to put my stock one back in.. for the simplisty.. but i ran mine with the stock shifter cable for a wile then switched to the b and m one witch is vary adjustable
(good)
good luck with yours
Old Jan 25, 2004 | 09:32 PM
Engine: 5.7
but like I said before...I don't even care about racing...I have never raced my car and never will....I just want it for the looks and such. I know how it says to change the cable and stuff....but I mean...I have no clue how to "adjust" it or anything like that...I'm not mechanic at all..
Old Jan 25, 2004 | 11:05 PM
Engine: 383 SBC
Here's what I cut off the stock shifter... I then cut the bracket off the BM megashifter right at the angle bend. I slotted out OEM bracket so I could adjust it with a bolt going through it and the megashifter.
Old Jan 25, 2004 | 11:10 PM
Engine: 5.7
where?
Old Jan 25, 2004 | 11:12 PM
Engine: 383 SBC
Err in uploading... here
Attached Thumbnails People using factory cable with Mega Shifter....come in please-img00057.jpg
Old Jan 25, 2004 | 11:15 PM
Engine: 5.7
that really dosen't give me much of an idea...on how it works out though...
Old Jan 25, 2004 | 11:18 PM
Engine: 383 SBC
K, give me 5 minutes I'll go take a pic of the setup... I gotta take the trim plate off first.
Old Jan 25, 2004 | 11:19 PM
Engine: 5.7
alright man...if it's not to much trouble...
Old Jan 25, 2004 | 11:30 PM
Engine: 383 SBC
Here's one. I had to resize it alot and my camera was dying on me so I don't really know how well it's gonna turn out.
Attached Thumbnails People using factory cable with Mega Shifter....come in please-img00060.jpg
Old Jan 25, 2004 | 11:33 PM
Engine: 383 SBC
Mine's bolted against the floor so if you use the stands yours will be a different angle and stuff. If you want another pic I can put one up. Basically you just slot out the OEM bracket and bolt it up to the shifter then get it where the cable fits on the shifter right... I had to drill out my pin hole on the shifter cable cause the bm one is a little bigger than stock.
Engine: 5.7
it's still very hard to see what has been done......maybe if you get some batteries some time...and can get some closer pictures....that would help tons...I just having trouble to see what needs to be modified to make this work...
Old Jan 25, 2004 | 11:36 PM
Engine: 5.7
I'm unable to do any of the installation right now...so basically when I start the installation....just try to see what I can do with it? Because it sounds like you didn't even really have to cut anything. Do you even use the brackets that came with the kit to bolt it to the floor? Sorry for all of the questions man...
Old Jan 25, 2004 | 11:46 PM
Engine: 383 SBC
Here's a slighty better one showing the slot in the stock shifter bracket. Here's the recap I hacksaw'd off the BM cable bracket on the megashifter at the place where it angles to meet the base plate. That gave me a flat mounting surface with nothing in the way on the driverside of the shifter. I then hacksaw'd the stock shifter bracket off at the lines show's on the left off stock shifter bracket. I then made a sloted hole in the stock bracket so when I went to put it on the BM I could slide the bracket till it fit the cable right That way you can take slack out of the cable and then when you tighten down the one screw of bolt on that side it holds the stock bracket against the megashifter baseplate. My new bracket pretty much takes up most of the area on that side of the shifter.
I didn't use the brackets at all for my application (formula) cause it wouldn't fit right they said and I didn't want to cut up my stock trim plate. By doing it my way I didn't have to cut the top of the trim plate at all and I didn't have to use there POS metal plate or boot (my boot was ruined when I bought the shifter 2nd hand). If you use the brackets your install will look a little different (taller and back towards the rear more) but should go the same way, I think. I only did it my way to keep the trim plate stock and I moved the shifter forward so much so I could get into 1st gear without notching the plate.
Attached Thumbnails People using factory cable with Mega Shifter....come in please-img00059.jpg
Old Jan 25, 2004 | 11:53 PM
Engine: 5.7
so then did you bolt the stock bracket (that has been cut off) to the B&M plate somewhere?
Old Jan 25, 2004 | 11:57 PM
Engine: 383 SBC
Yep that's the cable bracket you see on the driverside. It's just the Stock Bracket bolted on top of the BM plate. You can't really see the plate on that side cause of the neutral and reverse lights switches. But all that area there that has spot rust on it is the OEM bracket. I cut it out just I show'd on the OEM shifter picture. The bracket was around 1 3/4" wide by 1 3/4" long.
I pitched my BM cable bracket that I cut off. I never really plan on using a BM cable.
Old Jan 25, 2004 | 11:59 PM
Engine: 5.7
alrighty, that makes a little more sense...but I really can't look at much..because I can't install mine yet. So..if you don't mind, I'll just keep asking you questions about it when I Get ready to do it. Thanks for the info
Old Jan 26, 2004 | 12:05 AM
Engine: 383 SBC
Sure no problem... Make sure you loctite your handle too or else it will strip out like mine (1st owner didn't loctite it).
Old Jan 26, 2004 | 01:04 PM
Daishi's Avatar
Goto my cardomain, Check out my page that says BM install for TGO. I pretty much laid it all out. I can walk ya thru the install with the BM cable. I got time. Anywho, if you are really really stuck, The instructions are easy to follow... Seems like keeping the stock shifter is a lot of work, Heres a few pics:
Here is my stock cable, what it had looked like when I crawled under there
This is pretty much the only bolt to take out, there are two more in your pan.
Here is your new cable, just a few secs to get this hooked up
Heres every pic you need to hook up the cable
See how easy it shwas?
Old Jan 27, 2004 | 10:23 AM
Engine: 5.7
so fireturd350, if I end up doing it your way...is this the only part of the shifter plate that will need to be cut off?
Attached Thumbnails People using factory cable with Mega Shifter....come in please-cut.jpg
Old Jan 27, 2004 | 10:27 AM
Engine: 383 SBC
yep you just cut the BM bracket off that frees up space for you put mount the GM shifter bracket on that side.
Old Jan 27, 2004 | 11:43 AM
Engine: 5.7
alright, I tryed to do a little diagram on paint....is this is how to do it?
Attached Thumbnails People using factory cable with Mega Shifter....come in please-shfiterstuff.jpg
Old Jan 27, 2004 | 11:46 AM
Engine: 383 SBC
Yep that's how I did mine. I used the bolt hole already in the megashifter and made a slot in Factory bracket so I could adjust it.
Old Jan 27, 2004 | 11:48 AM
Engine: 383 SBC
I would just make sure it looks like the cable is going to align up right and stuff... cause I didn't use the mouhting brackets for my install... if the stock cable doesn't stretch that far well then you're up the river without a paddle and you will have to use the BM cable.
Old Jan 27, 2004 | 11:56 AM
Engine: 5.7
I see what your saying there too....it seems like if the cable wouldn't be long enough when adding the factory bracket...then I could just make a long one....so it would reach. I'll just have to check it alllll out when I get ready to install it. Did you have much troulbe with the wiring or anything?
Old Jan 27, 2004 | 11:59 AM
  #42
Engine: 383 SBC
Other than it being a mess trying to squeeze it all into the small area under the trim plate nope. I just follow'd my BM megashifter instructions.
Old Jan 27, 2004 | 01:24 PM
  #43
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I got your pM, sorry I can't be of more help, my memory of the install is gone, lol.
What ever bracket the cable needs to hook into needs to be cut off and have the old shifter bracket put in its place.
Old Jan 27, 2004 | 01:38 PM
  #44
Engine: 5.7
I've been messing around with it....and reading through the instructions just to get ahead start. I was messing around....puttin the indicator cable onto the shifter..and it seems like it dosen't want to cooperate very well when it's all connected together....does it just act like this? Or is something wrong..lol
Old Jan 27, 2004 | 02:44 PM
  #45
Engine: 5.7
can someone take a picture of the bottom of their B&M shift plate for me? I took mine apart and can't figure out how to get it back together...I think that's why I can't get the shift indicator cable hooked up right....
Old Jan 27, 2004 | 03:20 PM
  #46
Engine: 5.7
edit:
nevermind...I think I got it..everything is lined up and working fine.
Old Jan 27, 2004 | 03:34 PM
  #47
Engine: 383 SBC
I didn't put the indicator on mine. I just go by if the rev trigger is locked or not. Good Deal! Congratz! I think I had around 9 to 10 hours install in mine... course I hand sew'd my new leather shifter boot (that was pita).
Old Jan 27, 2004 | 04:23 PM
  #48
Engine: 5.7
hey man, do you know if the Toque Converter Lock-Up is wired to the switch that B&M provides?
Old Jan 27, 2004 | 05:08 PM
  #49
Engine: 383 SBC
For that I believe you need to purchase a relay from radio shack. They should give you the part numbers in the instructions.
It's not really the lock up function. If I remember right it only affects idle at Park and Neutral or something like that. So mainly you don't really need it.
Old Jan 27, 2004 | 06:06 PM
  #50
86WS6_T/A's Avatar
Car: 2003 Mach 1
To tell you the truth, I thought about trying to keep the stock cable and after I added up all the cutting and bolting and adjusting I'd have to do, I installed the supplied cable in 10 mins.
you pull 2 bolts on the pan, bolt in the cable bracket. Unbolt the factory shift arm, bolt the supplied arm back on. Then put the shift arm in park and the shifter in park. Adjust cable. Then make sure it hits every gear (did the first time for me)
Not all that bad... I agree, it was the easiest part of the swap.
