How to take off doors?
Old Feb 4, 2004 | 07:08 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
How do you take the doors off? Is it pretty simple or hard? I have a parts car that has power windows and door locks so I want to put them on my 83. Any tips and suggestions are appreciated. Thanks.
Old Feb 4, 2004 | 07:22 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Unbolt the top three bolts, then on th bottom you take the spring off, you need a small spring compressor, thne there is a small lock on the pin you need to pop off, once thats done, pull the pin out sand you got your door off. But make sure you take the door pannel off, and take the harness out through the hold on the front....
Old Feb 5, 2004 | 02:36 PM
jaredjames's Avatar
Car: 1982 Berlinetta
yeah or you can just not bother with the springs and pins, and just remove the inner kick panel and access the lower hinge bolts that way. when you put it back on, the top hinge that has the three bolts, needs the bolt that is closest to the fender in first. otherwise it is a pain to tighten it.
Old Feb 5, 2004 | 02:38 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
so if I just remove the kick panel on the interior of the car i can access those bolts? That seems like an easier way.
Mike
Old Feb 5, 2004 | 03:53 PM
jaredjames's Avatar
Yep, there might be a dust cover or something that is behind your inner kick panel, just scrape that off. The hardest bolt will be the one on the lower hinge closest to the fender, because you have to reach your arm through the fender to reach it. good luck.
Old Feb 6, 2004 | 03:52 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I just took mine off to paint the car, the easiest way is the first way described, undo the three bolts on the top hinge, and pop the spring and pin off the bottom hinge. Its a pain to get the three bolts off the bottom hinge. just pop your spring out, and hammer out the pin.
Old Feb 6, 2004 | 07:06 PM
Charged350's Avatar
Car: 87 IROC Z28
I work at a body shop, and thats how we do doors, so i presume you should too, becuase if you move around the bottom hinge thats bolted tot he car, youll never get them to line up good...
Old Mar 6, 2004 | 12:14 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
can I get the small spring compressor at like Kragens or Pep boys? Im gonna do the doors today.
Old Mar 6, 2004 | 02:23 PM
jaredjames's Avatar
just remove the bolts on the hinge, it'll be alot easier and it's not very hard to align it, all you do is you don't tighten the bolts down all the way before you stop and check the body lines and gaps.
Old Mar 6, 2004 | 04:14 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
damn!!! none of my auto stores have a spring compressor! all they have are valve spring compressors. where did you guys get yours at???
Old Mar 6, 2004 | 05:48 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
door spring
i got mine from classic industries i had the same problem it was 30 bucks
Old Mar 6, 2004 | 06:40 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I sell the GM door spring removal tool.
Lon Salgren
Top-Down Solutions
Old Mar 6, 2004 | 07:56 PM
BirdsofPray's Avatar
Car: 1991 Z28
Lon Salgren
Top-Down Solutions
Very sweet.....great site too. I've always seen the banner but never even checked it out until now.
Old Mar 6, 2004 | 09:21 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Lon Salgren
Top-Down Solutions
Great! Im glad you located in CA too that way I get it fast. I just placed an order for the tool and 2 lower hinge pins. As soon as I get my new doors on I can finally install my alarm!
Old Mar 10, 2004 | 07:55 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Got one door off But im stuck on the right door. The lower hing pin will not budge Do you guys got any suggestions or tips for me? Thanks!
Old Mar 10, 2004 | 10:06 PM
lonsal's Avatar
Spray with KROIL penetrating oil. I've had to cut some lower hinge pins in half with my Dremel tool and anbrasive metal cutoff blade, then pry out the two pieces.
Lon
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
