Map Pouch Removal
Old Feb 10, 2004 | 08:51 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Map Pouch Removal
What's the easiest and/or proper way to remove that map pouch?
Old Feb 10, 2004 | 09:49 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
It has 4 plastic clips on the back similar to those that hold the door panels on. I'd get as close to the clip as possible with a scraper or screwdriver and slowly pry it up. It may be easier if you can pry it up from both sides of the clip at the same time. I can't think of any other way to go about it.
Old Feb 11, 2004 | 12:16 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
The clips are actually a little different from those of the door panels. These clips are designed to stay in permanently. If you have power windows or locks those clips that hold the wire to the door are the same concept. Basicly if you can get in behind them and squeeze them with pliers would be the proper way. If you don't want to pull you dash out to do that. Be careful when pulling those clips out with screw drivers or whatever you use (A window Crank Handle remover from autozone is best bet) the more sureface you can push against the lest chance of cracking your dash.
Old Feb 11, 2004 | 12:55 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Why do you want it out. I think it looks nice. Gives it a different type of feel.
Old Feb 11, 2004 | 07:30 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Thanks guys...I'll see what I can do....
Don't want it out, I'm swapping to a nicer pouch.
Old Feb 11, 2004 | 08:27 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I just grabbed on an PULL!!... I broke two of the little plastic tabs tho .. Mine I think had 6 not four
John
Old Feb 11, 2004 | 01:37 PM
nolanr0413's Avatar
Car: Trans am
just pull .
Old Feb 11, 2004 | 02:01 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
MY car didn't have one when I bought it. I found a good one at a junkyard for 2 dollars. I bought it and just snapped it inplace.
BTW in my car there was some sort of plate behind the dash area that rattled like hell until I put a new puch on it.
Old Feb 11, 2004 | 03:49 PM
prophecy xi's Avatar
i found on my 89 formula that the back part of the leather will fold down so u can access the clips from the inside of the pouch?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
greenyone
Sep 8, 2015 08:41 PM
