need help replacing front turn signal balb
Old Feb 11, 2004 | 09:01 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i need help replacing the front turn signal balb in a 91 camaro. i can get it out of the housing but i dont know how to get of the socket how do you do this? i am replacing the factory amber lights with clear balbs
Old Feb 11, 2004 | 12:53 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
reach under pinch the prongs together and twist, the socket will fall out, replace bulb. Put in and listen for it to lock into place
Old Feb 11, 2004 | 01:54 PM
Car: 1997 S10
how do you replace the balb i can get the secket out but how do you get the balb out the socket
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Push the bulb in a little bit, and turn it counter-clockwise about 1/16 of a turn.
When you put the new bulb in, be sure to get the little 'ti<x>ts' on the outside oriented the right way.
Old Feb 11, 2004 | 01:55 PM
tyty49's Avatar
Sorry
Old Feb 11, 2004 | 01:58 PM
jeriatric's Avatar
Press the bulb inward and turn
Old Feb 11, 2004 | 03:40 PM
prophecy xi's Avatar
If this is the bulb im thinking it is its should just pull out of the socket. Is it one of those punch bulbs?
Old Feb 11, 2004 | 03:41 PM
Is it the turn signal on the side of the fender?
Old Feb 11, 2004 | 06:52 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
If its the one on the fender, take it out of the fender, its a small 194 bulb, grab it with two fingers and PULL,,simple as that, take the new bulb stick it in, and your done, if you are changing the housing to a clear lenz, take it out of the fender, the socket will rotate one way or another, pull it out and stick the clear lens on. done.
Old Feb 11, 2004 | 07:19 PM
Car: 1997 S10
thanks for the help it looks really cool
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
TheExaminer
Aug 25, 2015 07:34 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
