clear side marker instillation questions
Old Feb 11, 2004 | 07:27 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i was woundering how hard it would be to put in the clear sidemarkers on a 1991 camaro
Old Feb 11, 2004 | 07:31 PM
Flyersman29's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
pretty easy once you figure out how those stupid metal clips work in terms of accesibility, you shouldn't have any problems
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
It only takes a few minutes if you have smaller sized hands,I had to un-bolt my horns on one side,move my battery just a bit on the other side,because my damn hands wouldnt fit.
Damn son is never around when I need him!
I got mine from ProCar parts,make sure you put yellow bulbs in place of the clears
Old Feb 11, 2004 | 08:41 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
i got mine from procarparts.com also. Took about 30 minutes to install, mostly because it was so cold out. I had to remove my battary, unbolt my horns, and unbolt my canister on the passanger side. Look at the clips before u take the side marker off so its easier to understand how to get them back on. This was the best $38 i ever spent on the car
Old Feb 11, 2004 | 08:56 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I had to remove the horns also... but I guess I have small hands, I didn't have to move the battery...
Old Feb 11, 2004 | 09:43 PM
Mathius's Avatar
Why don't you guys just reach in under the fender? Takes 5 minutes apiece.... and I have a '92, which has the lowest gfx package.
Mathius
Old Feb 11, 2004 | 10:06 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Easy mod and it looks great...
Will
Old Feb 11, 2004 | 10:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Mathius
Thats what I did and my car was lowered as well. I barely fit but it was cake from underneith once your figure out those stupid metal clips. I didn't even need any tools and it took me about 15 minutes.
Old Feb 11, 2004 | 10:17 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
im thinkin im might give them a try. i think the will look good on white. I have one question does the kit have bulbs,lens, etc. I have looked at those sites to see im to tired its late.
Old Feb 11, 2004 | 10:30 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You re-use your stock bulb assembly. It twsits out of the stock amber lens and you put it into the clear one. The bulb is yellow so you may want to look at getting a white bulb for it. I need to do that because I hate the way a yellow light looks behind the clear corners.
Old Feb 11, 2004 | 10:36 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Transmission: 4spd
how do you buy them from procarparts.com. I tried clicking buy but it dont work. do i have to call??
Old Feb 11, 2004 | 10:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No you can do it online. Maybe their site is down. Try tomm or look on ebay.
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
