Will the ASCD SS hoo fit a TBI engine??
Old Feb 24, 2004 | 11:30 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I own a 91 Camaro with TBI will the ASCD SS hood fit on my car with this engine?? There add says "Available for the T.P.I. engine and carburetor engines. Please state when calling to order."
But nothing about TBI. Are there different types of SS hoods depending on which engine you have?? I thought they were all the same.
Old Feb 25, 2004 | 09:07 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
anyone??
Old Feb 25, 2004 | 09:15 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm not for sure....you could call Hawks and ask them....or you could email them.
Old Feb 25, 2004 | 10:13 AM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
probably, i had TBI and the big block hood fit fine, not positive bout SS though, although i'd think it wouldnt make a differnce
Old Feb 25, 2004 | 11:52 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
the ss hood gives about 2" additional clearance over the stock hood. since the tbi fits under the stock hood, then it definately will fit under the ss hood
Old Feb 25, 2004 | 12:53 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
order it for a carb. TBI and carbs sit on the engine the same way, and use a very similar (if not identical) air cleaner housing.
Old Mar 1, 2004 | 07:37 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
yes I have one on my tbi. not sure why they give you the tbi/carb or tpi option because they only make one hood. order it and enjoy
Old Mar 6, 2004 | 03:16 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Got an e-mail from ASCD and they say they have them listed that way because they had planned on making two different versions. The top would be the same for both but the underside would be different depending on which type of motor you had for directing air flow. They have not designed the ram air boxes to fit the motors yet so the hoods are the same for now
Old Mar 7, 2004 | 09:33 AM
deadtrend1's Avatar
correct
For now, the outlet holes for the air are under the hood in the corners on both sides where the battery and evap. canister are located. That is unless they changed design since i owned mine.
What i did on my Old bird, was cut out the area behind the vents and its put air towards the air filter, only problem was that it made the engine constantly dusty.
Old Mar 8, 2004 | 03:23 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
anyone have a picture of the underside??
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
R3500
Aug 17, 2015 12:16 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
armybyrd
Aug 10, 2015 09:23 PM
