installing 4th gen dash
Old Mar 11, 2004 | 11:32 PM
bladz's Avatar
Car: 86 firebird
Engine: 3.8 turbocharged GN motor
ok i started my install tonight, actualy got the 3rd gen dash out and man it was a bitch. maybe its just because ive never done it before and was going blind but hey gotta start somewhere. anyway tommarow everything should be ready to start going in and i got a friend coming over to hook up wiring harnesses while i do the physical install. anyway ive read up alot on the actual install and think i have a pretty good idea of what needs to be done but if anyone has tips or suggestions or even questions, please feal free to leave a post.
thanks to everyone here for all the info and writeups that WILL make this thing happen
Old Mar 12, 2004 | 01:47 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Right on, just be sure to post pics of the aftermath! I know a lot of people will chant for a guide on how to do it. Honestly, after fitting mine in there, there's no need, I found it to be a rather simple procedure. HOWEVER, trimming the topmost pad part will require some time, patience, and accuracy. IHI suggests the windshield being removed for optimum results. I haven't gotten to this stage yet personally.
Old Mar 13, 2004 | 12:20 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
couldn't you use the 3rd gen pad for a jig/cut line???
Old Mar 14, 2004 | 12:50 PM
bladz's Avatar
Car: 86 firebird
i have a large sheet of cardboard im going to use to make a pattern then cut outside the lines and use a dremell to get it perfect
Old Mar 14, 2004 | 01:32 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Seems reasonable enough, but I'm not certain yet
Similarly, that's a good idea too, bladz
Old Mar 14, 2004 | 08:55 PM
bladz's Avatar
Car: 86 firebird
ok all the wiring is done, even put in my system and an alarm while i was at it. now were hiding all the wires and about to bolt in the dash, then i think were gonna quit for the night and finish in the morning. yay working guages, hvac, and camaro headlight switch on a firebird :rockon:
Old Mar 14, 2004 | 10:33 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Any pics? I'm in the middle of putting a 94 camaro dash in my firebird, any pics would be appreciated. Also, how do you hook up the tach and speedo?
Old Mar 15, 2004 | 02:03 AM
bladz's Avatar
Car: 86 firebird
tach is a white wire on both the third and 4th gen, hook it up then connect the black/wht 3rd gen to the black/wht 4th gen thats the tach ground wire. plug the rest of the black ground wires into the other black wire on the 4th gen harness.
as for the speedo its almost pointless, i got mine to work but its soo far off that i either have a bad connection or it just wont work till i get it calibrated.
ill have pictures up of it tommarow all i could get was night pics today. they probly wont help much but ill be glad to answer any questions, just IM me.
Old Mar 15, 2004 | 01:25 PM
Faded's Avatar
Car: '91 Firebird
The HVAC is completely working? A/C and all?
Old Mar 16, 2004 | 12:49 AM
bladz's Avatar
Car: 86 firebird
yup all working, today i wired up all the system wires and indash screen wiring. tommarow i cut dash pad and clean up all the installs.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
