removing the stock shift knob?
Old Mar 26, 2004 | 07:59 PM
UncleSam89's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
removing the stock shift ****?
i want to replace my shifter plate on an automatic but i cant get the stick shift **** off, how do i do it? thanx
Old Mar 26, 2004 | 08:25 PM
jeriatric's Avatar
On the front side of the shift ****, there is a retaining clip. Pull it out with pliers and it'll come off.
Old Mar 26, 2004 | 09:37 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
To elaborate what he said,the clip is on te side facing the radio.You may need a flat head screw driver(w/a thin tip) to pry it out cause it is usually really in there.Then just pull the **** off.
Old Mar 26, 2004 | 10:41 PM
UncleSam89's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
do u pull the clip out? or push it in and then pull the **** off?
Old Mar 26, 2004 | 11:20 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Old Mar 26, 2004 | 11:56 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Pull it straight out towards the radio. it's almost likd a big staple. Once you have it out you will ''
Troy
So Cal
Old Jul 14, 2004 | 04:17 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
would that be the same for the IROC style? square
Old Jul 14, 2004 | 05:33 PM
91Zman's Avatar
Car: 1991 Z28
yep..
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
