angel eyes wired up and front signals
Old Mar 27, 2004 | 11:57 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
well I finally got my switches wired in. I have 4 switches which are hidden under the ashtray cover. I put my front signals on a 2 way switch so that i can change them from blue to amber. just not to attract to much law enforcment attention at night. but just thought i'd take some pix as these turned out a lot better than the one in my sig.
hope you enjoy, let me know what you think, good or bad
lol
cheers!
Blake
ps, when you use the actual signal.. and say have amber on the switch. the blue's faintly flash with it.... I have the ground from the ambers into one line, and then the low beam into one line... which then goes to a switch, this is the same for the blue. so then what I did is just use a wire tapper to tap into the blue's high beam wire on each side... but I guess it grounds out some how, because it does the same for when the blues are on too.. unfortunatly its more noticable with the blues on and ambers faintly flashing. so I'm looking for a 3 post switch, meaning that if you looked at the back of a switch which has positions of on and on and in the middle off(in some cases it doesn't have the middle off), on the back it would have a total of 9 posts. so if anyone has seen these online or anywhere. let me know.... i'd prever the large connections on the back to use the female automotive wiring plugs....
cheers
blake
Old Mar 28, 2004 | 10:37 AM
CaysE's Avatar
I'm sure a few people won't like it, but let me be the first to say damn that's awesome!
Old Mar 28, 2004 | 11:01 AM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
I think it looks great!
Old Mar 28, 2004 | 11:04 AM
mikesz1984's Avatar
Car: 1984 z28
all i have to say is , how the heck did you do that with the headlights, or does it come in kit form.
Old Mar 28, 2004 | 05:00 PM
yamahaguy91's Avatar
Car: 88 camaro RS
Engine: that thing under the hood?
Transmission: a what????
sweet:hail: :hail:
how did you do that
Old Mar 28, 2004 | 07:33 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
the headlight kit comes like that, as far as my knowledge, the guy off ebay who I got them from isn't selling them anymore..... and i've done google searches..... no luck. they're basically a smaller housing inside the stock size, and inbetween them is two 194 led bulbs, which reflect in between and cast the ring aroudn the light
cheers
Blake
Old Mar 28, 2004 | 07:41 PM
BadBowtie88's Avatar
That's badass bro. I like it.
Old Mar 29, 2004 | 12:12 AM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
if im not mistaken that is a bmw traid no? i was going to do this mode on my old beamer.
Old Mar 29, 2004 | 03:20 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Traid? Did you mean trait.....yeah newer BMW's have them. I'm not sure if I saw it here or if I saw it somewhere else, but someone had a tech article on how to make your own angel eyes, halo effect, whatever you want to call it lights. He basically took one of those clear wands that are used on home window blinds...the ones that when you twis them the blinds open (you can get them at home depot). Well he took that and put it in the oven to heat it up a bit to make it pliable and then bent it to shape..the guy had round lights so I belive he used a coffee can to get the shape, but not letting the two ends meet, but coming really close Then he wired an LED light and put it in between the ends so that when the LED was on the light would travel around...the way fiber optics work basically. Then he put that inside his headlight housing, can't remember what he exactly did there if it was inside or outside and he had some angel eyes.
Old Mar 29, 2004 | 05:02 AM
junkie's Avatar
Car: 84 camaro berlinetta
http://www.e-sonic.com/electrosonic/...ideAttributes=
ya i know its a hudge link but it should take you right to there 3 pole toggles ..but if you dont want toggles you can get selector switches as well like a rotary switch ...hope this helps ya find what you need
later
Old Mar 29, 2004 | 09:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I honestly don't care for it and think it's pointless but, I think you did a good job with it and it does not look all that bad.
Old Mar 29, 2004 | 09:23 PM
CaysE's Avatar
Blake, I think you broke the one on the driver's side. It looks like an LED is out.
Old Mar 29, 2004 | 09:49 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
no no, its actually blue Xenon bulbs in the far left one, because I ordered 4 pair but only got 3, however i was reinbursed, I'm getting like 5 more pair, go into the sides, the liscence plate, that one headlight, and the interior
cheers
blake
Old Mar 29, 2004 | 09:55 PM
That is so cool.
Old Mar 30, 2004 | 12:47 AM
305Tiger's Avatar
Car: 1987 Trans Am
Engine: LG4 305 w/emissions & A/C delete
Transmission: "...check!"
Axle/Gears: it's crap...they're stock!
nice!!!
DEFINITELY some sweeeet asssss lights there!
I'd do them on my 87 T/A but $ is sorta tight right now and besides....I just upped my fogs to H-3 100W's and those are pretty nice by themselves!
Yeah, the Angel Eyes are the newest Euro thing to do on imports.
-G
Caspar
Jun 19, 2016 11:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
