Couple ?'s on filling holes & primer
Old May 5, 2004 | 11:00 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Im going to be filling the holes for the original 3 piece spoiler since I now have a high rise. I am going to be doing it myself using body filler and the metal screen with an adhesive backing. Should I put the metal screen on top of the hole or just put it behind the hole? Or should I do both?
I will probably primer those areas and a couple other things like my rocker gfx and my rear bumper cover since I am getting my car painted in like 2-3 weeks. I dont have a spray gun so unfortunately it will be by spray paint. Is there anything wrong with primer in a can? Would I also need to get primer sealer? And should I primer my car before getting it painted? Thanks for the help.
Old May 5, 2004 | 11:17 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
I wouldnt use the metal screen. I would go out and but some fiberglass sheet and resin and use fiberglass. But either way be sure to "dent" in around the hole s you have some area to put the filler. Otherwise it will "pancake" or crack.
Old May 5, 2004 | 11:28 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
the right way to do it would be to have the holes welded. if you're getting it painted anyway, see what the shop would charge to do those. if you don't have access to a welder, and the shop charges to much, then i would go with fiberglass like 89305RS said. make sure you sand down to metal a few inches around the holes, so you're not putting any filler over paint. if you're going to fix it a few weeks before they paint it, you're gonna need to cover it with something. since it's not that long a time, spray can primer/paint should protect it fine for the time being, but i would make sure that you or the shop removes it before it goes in for paint.
Old May 5, 2004 | 01:01 PM
89305RS's Avatar
I dont like welding in a hole fact being is that if it gets too hot the metal will warp and have waves in it visable when painted. Also youre flirting with a new back window when you weld near it. Constant heat changes can shatter glass. But yoes it would be better to weld but fiberglass is just as good.
Old May 5, 2004 | 02:46 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Ok since I dont have access to a welder and would rather put the money towards the actual paint job I will probably go the fiberglass route like you guys said. If I went the fiberglass route do I just apply that on the outside of the hole or inside/both?
Im trying to do as much prep work as possible to cut down on the cost of the paint job. Do I need to primer my whole car or do I just need to rough the paint up?
Old May 5, 2004 | 03:17 PM
89305RS's Avatar
1. you have to sand all of the paint off to bare metal!!
2.ok say this is your hole (no pun intended )
__ __
3.You want to "ding" the rim of the hole to make it "dip" in like this:
__ __
4.Then you want to mix the resin according to the directions.
5.put it around the rim and inside the "bowl"
6.cut a peice of the glass to about 1" too big for the hole
7. put the peice in the hole pushing around it and INTO THE HOLE you do not want it to be flush at this point.
8.let it set up overnight
9. sand it smoothe with an orbital sander
10. fill bowl with filler or fiberglass filler
11. sand smoothe again
12. primer and your done!!
Old May 5, 2004 | 03:18 PM
89305RS's Avatar
damn it didnt come out right BUT you get the point right?
Old May 5, 2004 | 03:19 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
its cool man. I get it. this is my first time doing body work so I just want to make sure of everything.
Old May 5, 2004 | 03:50 PM
89305RS's Avatar
cool glad i could help out
Old May 5, 2004 | 05:34 PM
Afroman's Avatar
Car: 1983 Black Z28
Engine: 350 5.7 Carb
Transmission: Standard
Fiberglass would be better because if you used the metal mesh.. that mesh could begin to rust from underneath .. and then you would have hidden cancer.
Old May 6, 2004 | 08:14 AM
89305RS's Avatar
I think the mesh that hes talking about is the mesh that comes in the bondo kit. I believe that its aluminum. But great point though.
Old May 7, 2004 | 07:26 PM
3gc's Avatar
3gc
Car: Z28
This thread inspired me to shave my antenna...
The red stuff is glazing putting to fill in a few pits.
Old May 7, 2004 | 07:29 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Nice work man I want to shave mine too. What did you do with the antenna? So did you just put a fiberglass mesh over the hole and fill with filler?
Old May 7, 2004 | 11:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you are going to use filler only (which, provenly on commercial steel doors, works very well and last despite opinion of the method), use Z-grip (if available) made by Evercoat.
Do the normal filler prep to the outer surface and, if you can, rough the edge of the hole (with a file or whatever).
If you can, rough the back side of the hole as well (not a 100% needed step as Z-grip sticks to just about anything).
Place 2.5" masking tape (or make a wide strip from smaller pieces... doesn't have to be masking tape either really) over the backside of the hole.
Firmly press (important) the filler into the hole and then smoothe out as per normal using body filler.
Let cure (the longer the better for shrinkage purposes) and level.
Prep as per normal for paint.
After finishing prep.. remove backing tape and seal (paint, cold galv, galvaprime, epoxy primer, etc.) the exposed filler.
It's superficial to dimple the metal around the hole but, it doesn't hurt either as it is a little extra bonding area for the filler.
Just my opinion though.....
Old May 7, 2004 | 11:22 PM
3gc's Avatar
3gc
Car: Z28
I removed the antenna bracket and pulled the wire out of the car. I was going to take the wire off the bracket and put the wire with a mini antenna that they sell at pep boys or whatever inside under the dash so i'd have some sort of antenna if i ever wanted to listen to the weather forecast of something . But when removing the wire from the bracket i accidently cut it. So i won't be doing that until i get a chance to pick one up at the junkyard.
Old May 14, 2004 | 04:15 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Ok, I filled one side and put some spray paint primer on but the areas that have fiberglass stand out. Will that go away or how do I fix that? Will more layers of primer make fix that?
Old May 14, 2004 | 05:07 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
shaved my antenna too...welded the whole up and finished it with duraglass, bondo, and glaze...came out great for a black car.... https://www.thirdgen.org/techbb2/sho...hreadid=191750
Old May 17, 2004 | 11:43 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
ttt
Old May 17, 2004 | 03:02 PM
3gc's Avatar
3gc
Car: Z28
I kept sanding until the top layer of resin that i put over the fiberglass was about level then i put some glazzing putty over it. If you are going to add some putty be sure to sand down that primer first.
Old May 17, 2004 | 03:21 PM
89305RS's Avatar
It has to be FLUSH with the metal no question. Otherwise you WILL have a pancake on there. MAKE SURE IT IS FLUSH!! Find a straightdge or something. Make sure it dosent stick up from the metal.
Old May 17, 2004 | 03:55 PM
3gc's Avatar
3gc
Car: Z28
I didn't explain that right, sorry. 89305RS is right.
Old May 17, 2004 | 04:30 PM
89305RS's Avatar
You explained it fine, I just went a little more in depth with it.
Old May 17, 2004 | 06:58 PM
3gc's Avatar
3gc
Car: Z28
Here's the finished product. The clear is still wet in this though so it'll look better once it's dried. I'll take a new picture tomorrow.
Lol, that's awesome. I've never been able to get a reflection of myself in a picture of my car. I can't wait to see what this'll look like all wet sanded and buffed.
Old May 20, 2004 | 06:28 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
How am I doing? How many coats of primer will I have to put on so its not visible?
Old May 20, 2004 | 06:39 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Well I put some primer on and I answered my question Just need to put on some more coats so you wont be able to tell there was a hole there. I cant wait to get my car painted!
3gc, when you filled in your antenna hole did you put the fiberglass cloth patch on the bottom of the hole? Is it hard to reach that area?
Old May 20, 2004 | 08:52 PM
3gc's Avatar
3gc
Car: Z28
I didn't put the cloth on the bottom. It seems impossible to reach it, atleast with the fender on the car.
Old May 20, 2004 | 09:01 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
so how did you fill it in? just put the patch on top? I will probably tackle the task tommorow
Old May 20, 2004 | 09:08 PM
3gc's Avatar
3gc
Car: Z28
First i used a ball peen hammer and lightly bent the area around it down then I put some resin over the hole, then the cloth, then more resin. I didn't do a perfect job either, so their might be a better way. When looking at it from the rear at about eye level you can see where the hole was but that's the only time. I'm happy with it for now though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Linson
Sep 21, 2015 01:08 PM
Glowsock
Sep 5, 2015 07:48 PM
