rear window louvers
Old Jun 14, 2004 | 01:39 PM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
rear window louvers
I bought an Iroc about a week ago that at some point had rear window louvers on it. When I picked it up, the louvers were in the back seat but there's a metal strip on the top of the window that the louvers attach to. Does anyone know how to remove this metal strip? I never plan on putting these back on but just in case I sell these at some point, I'd like to have all the hardware to install the thing again.
Old Jun 14, 2004 | 03:27 PM
dacboyz's Avatar
Car: 89 Camaro
Are you interested in selling them? I am interested in buying them maybe if its what im looking for.
Old Jun 14, 2004 | 06:42 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
put the hatch up all the way and there should be bolts under the bracket
Old Jun 22, 2004 | 07:04 AM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
I looked last night and the bolts are very straight forward, Thanks. One problem though. The hinge "pin" on the drivers side is sticking out so I cannot remove the nut to remove the bolt. Is there a safe and easy way to push the pin back in without busting out the hatch glass. That's the last thing I want to do just to remove a bracket....
Anyway, Thanks again.
Old Jun 22, 2004 | 11:48 AM
Car: IROC Z
Engine: 5.7
can you loosen the bracket and slide it over?
Old Jun 22, 2004 | 11:54 AM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
Nope. I'll try to post a few pictures later of what it is that I'm trying to do maybe that will help.
Thanks Again
Old Jun 22, 2004 | 02:51 PM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
Here's the bracket from the outside
Old Jun 22, 2004 | 02:58 PM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
Here's the picture of the drivers side hinge. I was unable to get a good picture of the pin but it's to the left of the right bolt. Does anyone know the best way to push these pins into the hinge? I assume brute force isn't the best way since breaking the glass is a possibility.
Old Jun 22, 2004 | 05:04 PM
Car: IROC Z
Engine: 5.7
take the hatch off?
Old Jun 23, 2004 | 10:34 AM
CrazedCamaro's Avatar
Car: 1989 RS Camaro
Engine: 305 POS
if your interested in selling the louvers, im more than interested in buying them. and if you take the hatch off, it will make this job much easier
Old Jun 23, 2004 | 11:56 AM
Car: IROC Z
Engine: 5.7
there is a high demand for the louvers, you wont have a problem selling them. i almost bought another set as mine were damaged via a basketball
Old Jun 23, 2004 | 01:31 PM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
I was guessing that from all the private messages I received after this post. First things first though, I still need to remove this bracket I'll give it a try again this weekend and see what happens.
Old Jun 24, 2004 | 08:07 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Be careful when re installing the glass bolts. Do not overtighten. I had a set of these same louvers back in 86 that I sold to a friend. I installed them for him. He hit a pothole and the rear window shattered. I guess I overtightened the bolts. Be careful of that.
As for removing them, use a box end wrench and just work it gradually. There should be no problem in loosening the bolts. As you said, pretty straight forward.
Not trying to hijack the thread, but I still have parts from a NEW factory set of louvers. I have the mounting hardware, ABS sides and most of the slats. I also have the 3rd brake light slats for a 91/92.
Old Jun 24, 2004 | 03:11 PM
Car: IROC Z
Engine: 5.7
i love em
Old Jun 24, 2004 | 03:25 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
My louvers, which came off the second day of owning the car, did not mount that way.
Are those factory? ANyone know the RPO for the factory piece?
Old Jun 24, 2004 | 04:03 PM
Car: IROC Z
Engine: 5.7
cragar made mine
Old Jun 24, 2004 | 09:21 PM
scottmoyer's Avatar
That set is not factory. My set that mounted that way came from a company that started with a K. I don't remember as it's been 18 years.
The set I have on my car now is a factory set. The part numbers have changed so I don't know the numbers. They had 2 different sets. The set from the 80's and the set for te 91/92. I believe the 91/92 sets are the only ones available today.
Unfortunately, the cragar set is the set that most people complain about as rattle boxes.
Old Jun 24, 2004 | 09:58 PM
Car: IROC Z
Engine: 5.7
sticky foam fixes that
Old Jun 26, 2004 | 11:35 AM
sllt1776's Avatar
Car: 89 Iroc-Z
i have a set of original equipment to sell. RPO DE1. The are faded but are in grat shape. Located in Seattle. sllt1776@comcast.net
Old Jun 29, 2004 | 10:33 AM
Car: 91RS_92Z28
Engine: 5.0_5.7
anyone know the rpo for the 91-92 w/ third brake light louvers?
Old Jun 29, 2004 | 03:53 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
if a bunch of people want yours and you're having trouble removing the brackets, have the buyer that is willing to meet at your house come and take it. rather than possibly breaking the glass trying to remove it, just swap hatches, then switch the decklids.
Old Jun 29, 2004 | 10:10 PM
MikeS's Avatar
So apparently the factory style louvers can be taken apart? That's what I'm gathering from one of the replies anyways...
If so, that'll make it easier to find a buyer for mine since it would cut shipping dramatically.
Old Jul 11, 2004 | 08:55 AM
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
company starts w/ a k is kobel, I got the aluminum center piece from kobel. I need some abs sides though!!!! and I'd love to have that factory set you got on the blue camaro still got them up in seatille?
When I got my car they had the same strip, I lifted the hatch took a wrench 15 mm or 13 i think and loosened em up and then had to finish them off by hand only need to do the inner one that goes through the bracket, once done gotta scrap it off its glued on the window as well. I have a razor blade holder called a widget or sticker scraper worked great.
Old Jul 11, 2004 | 05:34 PM
scottmoyer's Avatar
Kobel is the name of the company I had from years ago.
The GM part number for the 91/92 louvers is 12341693.
The factory set can be taken apart, but I wouldn't do it. The slats are glued to the ABS sides and are not very easy to put back together. Take it from me, I've put 2 factory sets together and it isn't easy to do alone.
Old Jul 11, 2004 | 09:00 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
scott what does the factory ones look like vs other do you have a pic of them?
i have 3 peices with mine metal centers and abs side. i may be able to get a pic if needed. i need new abs side mine are poor condition but the middles are sweet.
Jeff
added: these are what mine look like
http://www.sfxperformance.com/parts/AST10518.htm
Old Jul 12, 2004 | 06:50 AM
scottmoyer's Avatar
without taking pictures of the factory ABS side pieces, the closest I could get now was a pic of my car with the louvers on.
You can see the edge of the ABS where the slats connect. I can get better pics tonight if needed.
Old Jul 12, 2004 | 08:22 AM
benoit454's Avatar
Car: 86 camaro
factory's are like scott's they have the plastic ends but when mated to the center they apppear to be one piece and solid.
Whereas yours and mine have the center and the tape on plastic sides just like your pic you dded from sfxperformance. The molded plastic looks like scotts but generally have a bigger opening between the louvers so its easier to see out them. The older cragar have a very tight gap in between them like say a 1/2 to 3/4 inch or so very tight. I'll find some pics
Old Jul 12, 2004 | 08:49 PM
scottmoyer's Avatar
Here's the factory set from the rear.
Old Jul 12, 2004 | 08:52 PM
scottmoyer's Avatar
forgot the pic....
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
