Left signal problem
Old Jun 28, 2004 | 03:04 AM
Vaker's Avatar
Car: 1986 Trans Am, 1989 Firebird
Transmission: 700r
Left signal problem
My left signal doesn't come back on left turns any more for some reason, it use to work fine before... :'(
Old Jun 28, 2004 | 11:26 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Check you're blinker fluid, it might be low. Also, make sure there isn't a leak in the blinker line. Go check under the car and there is a line going from left blinker to a cylinder under the dash.
Old Jun 28, 2004 | 12:17 PM
Faded's Avatar
Car: '91 Firebird
Have you tried replacing the bulb? Don't listen to the blinker fluid guys. =P
Old Jun 28, 2004 | 12:31 PM
Vaker's Avatar
Transmission: 700r
No, no blinker works fine, I mean when I make a left turn it still blink left
Old Jun 28, 2004 | 12:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It may be that you are not making a turn far enough for the cam follower to release the switch. I have that problem at times making a shallow left or right turn.
Old Jun 28, 2004 | 02:00 PM
Vaker's Avatar
Transmission: 700r
I tried doing a U turn still nothing, that was the first thing to come to mind too
Old Jun 28, 2004 | 02:22 PM
Faded's Avatar
Car: '91 Firebird
Oh hmm, I haven't had this problem with any thirdgen, but I did with my Corolla once. Replacing the lever fixed it. The catch was broken and when it would spring back it would not pull the switch all the way back.
Old Jun 28, 2004 | 06:50 PM
Cyfun's Avatar
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
This should be easy. Just pull the steering wheel off, pry out the ring to take off the notched steering-lock plate (this is easier to take off than it is to put back on, BTW), and notice the funny little springs on the top and bottom. You're probably missing the bottom one. I don't know if you can get these at a parts store, but they're easy to get at the junkyard. They won't charge you much, if anything at all. With any luck you'll find a car with the wheel already removed.
Fronzizzle
Mar 18, 2019 08:29 PM
bdads
Aug 24, 2015 06:01 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
