removing tint on defrost hatch
Old Jul 2, 2004 | 04:21 PM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
i have a friend who bought her camaro with a hack tint job that's peeling on her back hatch. she said she took it to a number of places in town, but they all said that they wouldn't remove tint on windows with defrost because it messes it up.
so, what should i tell her to do? is it ok just pulling it off?
Old Jul 2, 2004 | 04:36 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
i was wounderind the same thing becouse i need to replace mine also on my hatch but only half of my defoger works i hope theres someone out there that can help
Old Jul 2, 2004 | 04:48 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
I was told that if you want the tint removed/replaced and you want it to look good, the defrost lines will most likely have to go.
The reason for this is because the glue and residue that stays on the window after the film is removed needs to be scraped off right? Well unless you plan on being ever so careful and using an exacto knife to cut along the lines, you're most likely just going to scrape it off and take the lines with the glue.....depending on how old the tint is, they MAY be able to use chemicals to dissolve it enough, but dont bet on it (my old tint was 7 years old and they took my defrost lines off)
Old Jul 2, 2004 | 05:46 PM
Car: 1987 Iroc-Z28
Transmission: auto
well i read in some other posts about some solutions to take off the residue left from taking tint off...just not sure if pulling the tint off will pull the defrost lines off..
Old Jul 2, 2004 | 11:32 PM
Car: 1997 S10
what would happen if i where to use a heat gun? would it harm the defroster? or would it even work?
Old Jul 4, 2004 | 07:40 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I tried a heat gun on my side widows.Barely made a dent (so to speak).Brake cleaner & a x-actxo blade works real good on disolving the tint residue.Dont know about the defroster lines though.
Old Jul 5, 2004 | 12:25 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I took mine off with not many problems at all. I used Lacquer Thinner, Water, a Razor Blade, and some Fine Steel Wool....looks great...dosen't mess the defrost up or anything.
Old Jul 5, 2004 | 08:59 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Just replied in another post. check it out, try it. let us know if it works. This technique is what the pros use in FL without any issues.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
2012sergen11
Sep 7, 2015 11:37 AM
