Updated Pics Of Aluminum Door Panels
Old Jul 24, 2004 | 06:14 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
The first pic shows the panels with almost all the holes cut. The one on the right has several small holes cut in an attempt to lighten it up to the same weight as the original cardboard versions. I only managed to shave off about 50 grams and the aluminum versions weight about 300 grams more than the originals. I'd cut more holes or larger holes, but I had concerns about the foam and vinyl not sticking properly.
Old Jul 24, 2004 | 06:17 PM
Engine: 5.7L TPI
The next pic shows the passenger side door panel installed. It fits perfectly! Perfectly after I trimmed it about 10 times! I got my original pattern off of a junkyard door that was less than perfect, so that explains that. More pics coming if you guys are interested.
Old Jul 24, 2004 | 06:48 PM
nolanr0413's Avatar
Car: Trans am
how r u going to finsh them , engine turning, polish, paint . ?
Old Jul 24, 2004 | 07:31 PM
Metal383's Avatar
Car: 84 T/A 70 Chevelle SS 78 T/A
Engine: chevy 383 Chevy 496 Pontiac 462
Transmission: built THM700r4 Richmond 6 built TH400
Re: Updated Pics Of Aluminum Door Panels
I believe that answers it
Old Jul 24, 2004 | 07:46 PM
MikeS's Avatar
Looks like you did a great job getting your pattern down and cutting everything cleanly.
How come you chose to work with aluminum rather than a plastic?
Old Jul 24, 2004 | 08:42 PM
nick418's Avatar
Engine: L98, Hemi 6.2
aluminum is gonna be a very cool set up, cant wait to see the rest
Old Jul 24, 2004 | 09:08 PM
Engine: 5.7L TPI
Thanks for the compliments. I had considered using reinforced plastic (circuit board material) instead of aluminum, but I thought it would probably be cost prohibitive. I didn't check on that though. I never considered using plexiglass because I think it's too brittle. I also ruled out fiberboard because of the possibility of water damage. As for the finish, I'm thinking of using leather, vinyl, carbon fiber, or all three. I'll probably stick with something pretty conservative for my design theme. That's in the works as I write this. I'll be sure to post pics when it's finished.
Old Jul 24, 2004 | 10:58 PM
3gc's Avatar
3gc
Car: Z28
Looks great so far. Are you going to use the original upper molding peice with the window sweep? Also wouldn't using metal produce some nasty rattles?
Old Jul 24, 2004 | 11:08 PM
Engine: 5.7L TPI
No, the original upper molding pieces were bent (lower in the center than on the ends), so I bought replacements from Year One. As for the rattles, vinyl or leather will be wrapped around the edges onto to the back side of the door panel. That will take care of the edges. As for the center, I plan to adhere foam onto to the back side of the panel to take care of any other rattles.
Old Jul 24, 2004 | 11:24 PM
3gc's Avatar
3gc
Car: Z28
Ah, that is a great setup you got going there then. How much did those moldings from year one set you back. I need to pick up a set sometime.
Old Jul 25, 2004 | 03:50 PM
Engine: 5.7L TPI
They were $139 a set. Kind of pricy for less than perfect in my opinion. But, since there aren't any other options, what can anyone do?
Old Jul 26, 2004 | 12:08 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Looks good, when you put the foam on the back side pay attention and don't make it so that it restricts the movement of your lock rods, or your power locks if you have them will have trouble.
Old Oct 30, 2006 | 04:50 AM
Engine: 5.7L TPI
It's been a while since I even had a chance to think about these door panels. I decided not to use them. I tried pretty hard to lighten them up by punching a series of holes in them, but they're still heavier than the originals. I decided to keep them as templates, but I will probably fabricate some out of fiberglass or carbon fiber instead. If that doesn't work out, I will just use fiberboard. Honestly, it's not like I run my car at the track or anything, so a couple pounds probably doesn't really matter that much. I'm setting it up for pro touring and the thicker fiberboard would probaby dampen some road noise anyway.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
