Haha.. woops. Key broke in the door lock.
Old Sep 7, 2004 | 07:51 PM
CaysE's Avatar
Well it's about time. That key has survived a lot, and it is now officially stuck inside the lock cylinder. Where did everyone get their lock cylinders, and did you buy a whole set (doors, t-tops, hatch) or just a replacement? Is it possible to get a replacement for the same key with my spare?
Old Sep 7, 2004 | 08:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
the dealership sells them, pretty cheap too, I can get both doors for 50 bucks canadian
Old Sep 7, 2004 | 08:37 PM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
If you're not looking for BRAND NEW lock cylinders/keys, then I'd try a local junkyard.
You'd probably get an entire set for around $10.00.
Old Sep 7, 2004 | 08:51 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
good luck finding the keys at a junkyard
Old Sep 7, 2004 | 08:55 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i got both of my cylinder locks with keys for 15 dollars from Autozone.....brand new!
Old Sep 8, 2004 | 11:44 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
If you're only gonna replace one, just take the cylinder to a locksmith, shouldn't charge you more than $15 to get it rekeyed to match your other locks... unless you broke the only key you have... then I'd say go for the AZ ones.
Old Sep 8, 2004 | 12:21 PM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
On my GTA, only 1 lock cylinder on the entire car worked (drivers door). The passenger side is jammed - key only goes halfway in... the hatch was corroded solid.
I got all new lock cylinders from GM (I couldn't find any aftermarket places around here that could get me a hatch lock cylinder - they all told me either it was a special order part, or you could only get them from the dealership). All 3 cost me around $80 Canadian (after taxes). It cost me $11 each for a lock smith to assemble and key the locks. If you got 1 key he will use the existing code.
Old Sep 8, 2004 | 05:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You said you've got a spare key? Yeah, have one cut... why not... see if it works or not. Or, bring it to GM and have them determine the key code. (The key's teeth actually lines up along a grid, and that's how GM can re-cut a key without you giving them a key - in theory, anyway. ) If you've got the GM Service Manual, the grid is in the back of the book, in the body service section.
Old Sep 9, 2004 | 02:18 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: Haha.. woops. Key broke in the door lock.
All you have to do is bring it to a competent locksmith and they can remove the key from the cylinder. I had the same thing happen in our 1991 GMC Jimmy
Chris
Old Sep 9, 2004 | 03:05 PM
CaysE's Avatar
Thanks for the replies, everyone. I think I'll order a new set from GM. I'd like to have new GM keys for one, and the lock cylinders on both doors are going bad as well.
The best part is, I can still use the half key I have to lock and unlock the door.
Old Sep 10, 2004 | 11:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! Ya know you can actually disassemble the lock once you remove it from the door; when I bought my car, the little black "cap" over the key slot was broken. Brought it in to a GM dealer, intending to buy a set of locks, but the guy actually sold me a new cap AND put it on for me. Only cost $5! Too bad that place went out of business
Old Sep 13, 2004 | 04:57 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Got mine from the Paddock. Hatch, doors, keys, and gaskets were $43 shipped.
All GM btw.
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
