best way to prep ground effects
Old Sep 23, 2004 | 06:23 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
ok i bought gfx ( front spoiler, both sides, bumper n quarter panels) off of a 89 iroc-z to put on my 84 z now what would be the way to prep the front spoiler n bumper there like rubber i dont think i can snad it cuz it would mess it up wouldnt it?? n the sides and quarter panels i think are metal can they be sanded too ? i thought o f also paint stripper but i think that would be a nightmare that it would eat the gfx all up . can someone gimme the best method to prep these gfx so i can put them on my 84 Z???
Old Sep 23, 2004 | 07:07 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
sand with 400, then with sand with 600, hell even 1000 if you want but if you have big chips or scufs then youd gonna have to start with a lower grit.
then buy a ratttle can of primer and spray away..
Old Sep 23, 2004 | 08:22 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
i did mine with 220 and they came out fine.
Old Sep 24, 2004 | 12:52 AM
MoroteZ28's Avatar
sounds good i think i might go wit 220 i dunno i will see tomorrow maybe any more suggestions? oh yeah and also i have a 92 z28 front bumper comin as well what sand paper should i use for that?
Old Sep 24, 2004 | 07:04 AM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
How are the GFx now? Did you buy them used, or new? Are they painted? E-coat?
If painted, what kind of shape is the paint in?
If painted, In good shape, or in E-coat, sand with 400 dry, seal and shoot.
ABSOLUTELY NO RATTLECAN!!!! Definitely use flex... Some will disagree... but use it, You'll thank me later.
Old Sep 24, 2004 | 07:12 AM
MoroteZ28's Avatar
ok the gfx are in pretty good shape as in paint n im usin the 220 n its looks like its gunna take alooong time if i use this grit n yeh they were used but in good condition so wat kind of sand paper should i use would 80 be good or too harsh?
Old Sep 24, 2004 | 07:36 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
wayyyy too harsh man, use 220, thats as rough as you can possibly get w/o ****ing up the plastic. it takes a bit of time, but its not that bad, and actually now that i think about it, i wetsanded mine with 220.
Old Sep 24, 2004 | 08:08 AM
MoroteZ28's Avatar
ok so when i prep it does it have to rid of all its color? or juhst sanded down enought to be smooth with hardly ne color left these gfx are hard to completly sand off im usin the 220
Old Sep 24, 2004 | 08:40 AM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
I don’t know about you, but when I did mine, I didn’t have the money to do a pro paint job. So I used Krylon “Fusion” paint. It’s made for painting plastic (all your gfx + both front & rear bumpers are a urethane plastic), no primer needed. My car is Chevy Artic White, so I used the white & then used Duplo auto paint (auto stores or Wal-Mart has it) in a spray can.
90% of doing a great paint job is prep work. So take your time.
If you do decide to use the rattle can method above, I highly recommend painting the parts & giving them the 7 days cure time. Fusion paint needs 7 days to become scratch resistant.
Old Sep 24, 2004 | 09:13 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
VERY, very true.
What color will you be painting.? amy metallics will lay in a 220 grit scratch. way to coarse.
Wetsand with 220 as mentioned above will be ok but not optimal.
No, do not remove old paint completely. you're asking for way more than you want to get into if you do that.
All you need is a tooth for the new finish to stick.
Old Sep 29, 2004 | 02:21 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
84 to 90-92 GFX
I have been reading/searching the threads here trying to figure out about changing out my 84 GFX to 90-92 GFX parts. So far I understand that they will all fit, but I will have to do the complete front, along with door pieces and rockers for them to match...Am I correct in my assumptions so far or should I stick with earlier parts?
Thanx, Cocacolakidd
Old Sep 29, 2004 | 03:37 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Re: 84 to 90-92 GFX
Thanx, Cocacolakidd
you have to change the complete thing gront rockers door piece and rear bumper and the quarter panel pieces.. the front nose is a little different as well I believe, and think you have to drill a few holes to mount the newer gfx
as for prep any grit between 220-400 is perfect you want to be able to sand it enough so the paint has something to adhear to but not so gritty that you can see the sanding through the paint.
Old Sep 29, 2004 | 06:17 PM
Car: 84Z & Porsche
84 to 90-92 GFX
As far as mounting the front bumper cover by drilling some holes, that's fine, and sounds easy so far...I also understand about the 200-400 Grit sand paper. I will just take extra time because there are two different colors of paint on it. The top color is red, which I want to eliminate completly....then it should be fine. Thanks, Ed.
$750 L98
Feb 1, 2025 02:25 PM
Thaney9
Oct 24, 2015 07:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
