115MPH to 145MPH
Old Sep 26, 2004 | 12:13 AM
NascarFool's Avatar
Car: 1989 Iroc-Z
115MPH to 145MPH
I changed the speedo in my 89 Iroc-Z today. I bought a 145MPH cluster and swapped over the speedo, fuel and charge gauges. I didn't swap out the tach because mine has the oil gauge built in and the other one had the oil gauge riveted on the tach. Unfortunately I payed way too much for the 145 cluster for the condition it was in. I had to do the wire repair on the trip odometer that was suppsed to be in working condition. I also painted the black mask with aluminum paint as shown on another post here. I checked all bulbs and lubed the speedo cable before I put it back together. I successfully removed the odometer assembly from the 115 speedo and transplanted it into the 145 speedo. The replacement speedo shows the correct mileage of the car. Please don't make fun of my "road map" dashpad. It will be replaced as soon as I can find one.
145 Speedo
Old Sep 26, 2004 | 12:54 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
looks good
Old Sep 26, 2004 | 01:37 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Car is running a little hot and it looks like your battery is dead Anyway it looks sweet, good job
Old Sep 26, 2004 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Nascar,
The plastic lens looks a bit cloudy. I've had great success in cleaning them up by using 3M Professional Formula Plastic Cleaner (for Clear and Colored Plastics), which I purchased at CarQuest. I used a drill, set at a fairly low speed, and a buffing attachment. Works great.
JamesC
Old Sep 26, 2004 | 09:58 AM
NascarFool's Avatar
Car: 1989 Iroc-Z
Originally posted by JamesC
Nascar,
JamesC
JamesC, I'll look for some today. Thanks for posting the trip odometer repair and the other speedo tips. I'll post another pic after I clean up the lens.
trans87
Old Sep 26, 2004 | 05:57 PM
JestahX's Avatar
Car: '85 Z28 Camaro
now you just need a new dash pad!
Looks good. Soon as i find the 145 Z28 tach ima buy it up real quick
Old Sep 26, 2004 | 06:06 PM
nick418's Avatar
Engine: L98, Hemi 6.2
looks great! For some strange reason i like the IROC Gauges better then the 90-92 design.
Old Nov 14, 2004 | 04:37 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
did you have to recalibrate anything when you switched from the 115 to the 145? I want to go for the same thing.
Old Nov 14, 2004 | 04:49 PM
JamesC's Avatar
The clusters are pretty much plug and play as long as you swap cable driven to cable driven and electronic to electronic--90-92 should be electronic.
JamesC
Old Nov 14, 2004 | 06:49 PM
OutLaw305's Avatar
Hrm, they didnt come any higher than 110 in the 90-92 years though did they?
Old Nov 14, 2004 | 07:47 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
i believe they had a 120 mph one in the 90-92 years
Old Nov 14, 2004 | 10:59 PM
OutLaw305's Avatar
in 90, didnt the irocs ave a 140 mph speedo?
Old Nov 15, 2004 | 12:40 AM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
yah the 90 iroc did. im not sure if any of the othe 90 to 92s did though. there is actually one in the classifieds right now that porkyzilla is selling.
Old Nov 15, 2004 | 07:37 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
SOME 1990 IROCs had the 140mph speedo. My wife's only has the factory 115mph.
Old Nov 15, 2004 | 10:36 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
personally, i want to get the 140mph speedo with Z/28 on the speedo. I saw one on eBay go for something like $75..looked great too.. but i didn't know anything about changing them out at the time and i didn't wanna screw it up.. oh well..
does anyone have any info on these? I heard somewhere (on here i think) that they were like a dealer option or used as a replacement by dealers or something.....
BTW, the speedo im talking about (the one i saw on ebay) the owner swore that it came from an 87 and was cable driven.
Rabbitt
ChevyZ71
Aug 13, 2015 07:30 AM
92RSGUY
Feb 11, 2005 10:25 AM
stuart69427
Nov 22, 2001 10:37 AM
Troy 85Z
Apr 10, 2001 07:58 AM
cobrakiller1989
Mar 10, 2001 10:33 PM
