Help. Hood release cable broke.
Old Oct 4, 2004 | 11:51 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Topic says it all. Went to pull on it the other day and it broke. Hood is latched shut and can't get it open. Any ideas on how I might be able to pop the hood open? Any help is GREATLY appreciated, being as I can't get into my engine bay now and I need to change the oil before I drive it too many more miles. Thanks.
Old Oct 5, 2004 | 09:48 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
If you remove some of the panels on the bottom of the car directly in under the latch you should be able to get your hand up there with a screwdriver and open it manually. It's probably a PITA but is doable.
Old Oct 5, 2004 | 09:50 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
where exactly did the cable break at ???
as long as the cable didnt break by the latch you should be able to find where it broke and cut it and take some pliers and pull the cable there and it will open
Old Oct 5, 2004 | 10:49 AM
RSpeed's Avatar
It broke by the latch. I'll get up underneath it and see about pulling off some of the panels and stuff out of the way. Thanks guys.
Old Oct 5, 2004 | 12:16 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have opened hoods with broken cables by getting underneeth and working the mech... It may be beneficial to look at another car to see how it is suposed to work.
Good luck
Old Oct 5, 2004 | 03:37 PM
megaracerx's Avatar
o really...good ideas an all...i just used a crow bar...
Old Oct 5, 2004 | 03:52 PM
okfoz's Avatar
Is that why your Avitar has a black eye???
Old Oct 5, 2004 | 08:01 PM
RSpeed's Avatar
Cool. Appreciate the tips . I'll give a try sometime tomorrow.
Old Oct 5, 2004 | 09:01 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
hey hope you get things figured out jus tohught id let you kno i love ur car man could u pm me some pics?
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
scottmoyer
Sep 7, 2015 07:06 PM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
