A/C delete differences
Old Oct 22, 2004 | 03:26 PM
colonboy14's Avatar
Car: Trans Am
On IROCZDAVE's website, he sells a complete non A/C kit with everything you would need to convert to 1LE heat. Are there any differences in the A/C vs. non A/C control boxes (the huge thing behind the dash), electronics, etc?
Where does the air come out of in non A/C cars? There wouldn't be any vents by your feet, would there? What about the little ones by the windows? There are 2 block off plates in his kit. What do they do?
His site
Old Oct 22, 2004 | 04:24 PM
MNformula350's Avatar
Having owned a non a/c car and converted my Formula to non a/c i'll give ya the best help i can recall.
The block off plates go on the dash ends by the doors, and replace the vents. under the steering wheel there would be 2 switches (like hood release type pulls) for left and right vent, instead of the vents on the sides of the dash a non a/c car has them on the kick panles that cover the bottom of the dash on either side. (i have my old ones off my 84 somewhere if i find them i'll try to get a pic). as for the controls a car with a/c uses vacuum control to change the selections and a non a/c car is cable driven.
Also just to note a non a/c Camaro never had the vent holes cut out on the dash, where as a firebird used block off plates.
Hope that helps.
Old Oct 22, 2004 | 10:52 PM
colonboy14's Avatar
Car: Trans Am
So the air only comes out of the two center vents, and by your feet. That's weird.
Old Oct 22, 2004 | 11:37 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Just curious but why would you want to block off vents?
Old Jan 17, 2005 | 08:11 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
also curious, how the hell do u hook up the cables and remove the vacuum lines? im having the hardest time figuring this out
Old Jan 19, 2005 | 10:25 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I'm going to be removing the A/C box on the firewall and installing the Non-A/C style box.
I didn't realize the difference in the vaccum-control -vs- cable control. Assuming I don't change the HVAC panel inside the car, will my heat still work correctly (using vaccum controls with no A/C)?
Old Jan 19, 2005 | 01:04 PM
colonboy14's Avatar
Car: Trans Am
I put on the non A/C box and the heater works fine. I think if you change the box inside the forewall w/ all the doors in it, you have to convert from vacuum control to cable control.
Old Jan 19, 2005 | 01:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the best way to convert it (imo) is also the easiest.
leave the under dash stuff alone, and replace the underhood part.
then you can change the control panel layover (if you wish) but i wouldnt go taking apart the air doors and blocking vents.
Old Jan 19, 2005 | 01:29 PM
GarageToys's Avatar
Good call. Thanx guys.
Old Jan 19, 2005 | 01:43 PM
That's all I did was change the panel, the actual controls are still for an a/c car. all iever use anyway is either the defroster (very far right) or teh max a/c setting to turn on the fan (second form left). It makes it look like a factory non a/c car. (under hood and the controls).....
Attached Thumbnails A/C delete differences-non-ac-control.jpg
Old Jan 19, 2005 | 03:23 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
do the controls come apart so that u can switch the plastic faces?
Old Jan 20, 2005 | 08:59 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
the camaro ones do..
its just a clear plastic cover with a printed sheetmetal/plastic piece under it.
atleast all the ones ive used have been that way. i had a 82 and a 91, so if they both have it, i assume all the years in between did.
Old Jan 20, 2005 | 10:03 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
MrDude ... you are the man, hah, thanks for the info about them panels, im just gonna switch them up on mine. and it will be ALOT easier than riping my whole dash apart. i have another question.... does anyone know what the 2 hard plastic vac lines go to that come out of the AC harness?
Frozer!!!
Jan 19, 2024 04:55 PM
BAMiller
Sep 14, 2015 06:38 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
