Anyone have luck with using 3M seam sealer over POR-15????
Old Nov 5, 2004 | 03:18 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Anyone have luck with using 3M seam sealer over POR-15? In another post someone recommended as do the 3M instructions, that seam sealer needs to be put over a primer base. Now the epoxy primer someone else in another post recommended me, I can't use. Number one I dont have a gun nor know anyone with a gun, and I am completely broke and can't buy a gun. I tried all around to find some epoxy rattle can primer but had no luck locally. Anyway, need to get my car done and wanted to see if anyone has just applied a seam sealer directly over POR-15 and how it worked out. For those who have no experiene with painting or applying anything over POR, please don't answer with "why couldn't you" or anything like that. Thanks, GW.
Old Nov 5, 2004 | 10:58 PM
comatose 88 WS6's Avatar
Car: Chevrolegs
why not just get some scrap metal and test it out prior to doing it to the car?
Old Nov 5, 2004 | 11:02 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
because that would be to easy Good idea. dont know why I didn't think of that. But if anyone else has actually done it let me know how it stuck for U. Probably be another week before I get to it.
Falconiroc
Feb 12, 2017 10:50 PM
4.8camaro
May 2, 2013 07:31 PM
rcurrier44
May 3, 2010 02:39 PM
jacque_strap
May 6, 2009 08:19 PM
TheScaryOne
Feb 26, 2008 01:49 PM
