pulled iroc badge off gfx what glue to put back on
Old Dec 14, 2004 | 02:46 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok well i was pulling the front end off and had to pull the fender as well so i was dropping the gfx when i pulled the badge never done it i just pride on a screw driver looks like i broke 2 of the rivets, im gonna need to be able to get it off later so what kind of glue should i use to put it back on???
Old Dec 14, 2004 | 09:10 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Use what GM used on alot of their factory replacements...
Double sided 3M Tape (3M is the best)
You can get it at Autozone, Adavance, Wal-Mart...
I use the one with the orangey/red backing (stronger), not the white.
Old Dec 14, 2004 | 05:47 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
duble stick tape, i use it at my shop for emblems all day, works fine.
Old Dec 15, 2004 | 01:44 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
its not gonna fly off at 150mph right ...these things are out of production :'(
Old Dec 15, 2004 | 05:57 AM
EvilCartman's Avatar
Car: '82 Z28
Nope, but maybe at 151 mph.
Old Dec 15, 2004 | 03:51 PM
redraif's Avatar
Use it on my out of production 2nd gen bird emblems! GM uses the stuff. Just make sure you clean both surfaces really well with alcohol before...
Old Dec 16, 2004 | 02:30 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
You can get new ones at yearone.com
Old Dec 16, 2004 | 02:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
clean it well.. use alcohol like suggested above...
then use 3M emblem tape... dont use a diffrent brand. even if its "ment for" emblems...
that stuff will make it stick on, even at extended speeds so high that your car will never reach them.
also, the sun and rain and tempature changes wont make it come off....
Old Dec 18, 2004 | 11:52 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
3M also makes a product called Trim Adhesive. I've had good success with it in glueing my emblems back on.
Old Dec 19, 2004 | 05:55 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
GM didnt use double sided tape on any of my cars they used adhesive. I have seen them put on both ways and i have taken them both off. The tape comes off way easier than the adhesive. I would go to your local parts store and ask for trim and emblem adhesive it comes in a tube like rtv. Its more messy but stronger. I have just never been a fan of double sided tape for anything.
Old Dec 19, 2004 | 02:46 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
Transmission: 700r4 x2
ive used two part epoxy before to put them on but forget about ever takin them back off, but the double sided tape usually works fine, clean the panel with alcohol, just don't drink it
Old Dec 20, 2004 | 12:08 PM
redraif's Avatar
Seeing as how you may want to take them back off. I again say 3M tape... the adhesive will be too messy and could damage the paint and the emblem if you ever want it back off.
Old Dec 20, 2004 | 12:41 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
if you use epoxy or 3M adhesive, the chances of getting it off again without breaking it are very slim.
Old Dec 20, 2004 | 01:51 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I call B.S if you use trim and emblem adhesive made my 3M which comes in a red box and it is tube inside. You are a friggin dumb *** to use an epoxy that is like super glue. GM uses the adhesive not double sided tape. I just took the badges off of the back of my gtp and they were held on by the black adhesive. Here is a pic didnt hurt the paint at all looks perfect. And by the way the dealer i bought the car from put their logo on the car with double sided tape and it took me just as long to get all the sticky off from the tape as the adhesive. I think it would be pretty hard to break a badge unless is was crumbling before u took it off. The factory badges were right below the key hole and were about a foot wide across the trunk.
Old Dec 21, 2004 | 10:12 AM
redraif's Avatar
Well the point is that we are comapring it to what GM uses on its replacement emblems. I have ordered multiple emblems (2nd gen birds) over the counter over the years and they have all come with the 3M emblem doubled sided tape.
But for giggles, the duallys original hub came with center emblems that had the adhesive GM uses. Well that lested about a year before it slung off. Took it in under warrenty they replaced it with more adhesive...slung off again. the next time I got it over the counter from them and installed it myself. The emblem came with the 3m emblem tape (grey tape with red tape backing) already installed. Well I put that one and and it stayed for 10 years. Took it off and replaced the hub and put the emblem on a new hub came off fine with a hairdryer to soften the tape. Then I got the 3M emblem tape from Wally world (again grey tape with red backing) and reinstalled again held fine for years!
In fact, I ordered the GM body side moldings. See the dually was made around the body change and they, at the time of purchase, did not offer them for a dually. So I got them later dealer compted. They came with the same 3M tape!
So if GM trusts the stuff, I do. I have great luck with all my emblems holding for years. And again have even removed and reapplied and had good luck.
A good trick for removal with 3M tape...get some fishing line and you can cut the tape B/w the body and emblem. Keeps you from stressing the emblem like you would if prying it off!
Old Dec 21, 2004 | 10:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
another thing.... thoes"tuner" bodykits you see on alot of crap cars...
they're held on only with 3M tape... and know what? they dont just fall off easily.. even after a couple years...
the width of the tape is so thin that you would never know its there... its about as thick as a glop of adhesive behind the badge would be.
im just pointing out that its not going to come off with the tape... you can use adhesive if you want, its your car.. its just harder to get off later.
Old Dec 21, 2004 | 11:57 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
when i bought my Genuine GM IROC-Z rocker emblems, they came brand new in the box, with double-sided tape.
Old Dec 22, 2004 | 01:49 AM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
Krazy glue anyone!???
Old Dec 24, 2004 | 11:06 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
mine too. now only if i had a bumper emblem in silver, id be hooked up!
use the tape, mang.
Old Dec 24, 2004 | 11:45 PM
Car: 1988 IROC-Z
no **** right... i cannot find the silver bumper emblem anywhere. that really sucks ***.
Old Dec 24, 2004 | 11:54 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
marine plastic polish works wonders on it. i have mine polished up nicely.... just dont get really close and see the 100000000 cracks it really has. :lala:
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
