paint
Old Dec 22, 2004 | 07:43 PM
chevy35086's Avatar
Car: Camaro z28 1986
Axle/Gears: 3.42's
paint
where u guys buy ur primer and original gm paint at?
thanks
Old Dec 22, 2004 | 09:40 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
any auto supply store should have it, they carry dupont and ppg most of the time, gm is dupont from the factory...but any company can maek the color as long as it matches.
Old Dec 23, 2004 | 05:46 AM
chevy35086's Avatar
Axle/Gears: 3.42's
so someplace like advance or autozone or pepboys?
Old Dec 23, 2004 | 09:40 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Old Dec 23, 2004 | 11:32 AM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
gm is dupont from the factory....
Not necessarilly, GM does as any other company, and takes bids for their supply. One year , it may be Dupont, The next, PPG and so on,
Note too, that "true factory" paint would never harden in the aftermarket environment, The factory cooks their paint at @300 degrees to flow and cure.
Old Dec 23, 2004 | 02:00 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
Buy your paint from an autobody paint supply company. Most of the time they will help you in getting the proper prep/primers you need, and will have it in stock. PPG, Dupont, and Sher-Williams are all good paints, but I would stay away from the BASF brand paint/primers (BASF is just real cheapy to me). Another word of advise, dont cheap out when it comes to the primer/sealer; you get what you pay for!
Old Dec 23, 2004 | 05:11 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
the paint at auto zone ect is not the right stuff to put on the body you can use it on miss parts but if you are going to prep the car for a PPG dupon or SherWill paint the cheapest way out on the primer end is rustolem/rusttuff primer from auto zone it is about $5 a can if you use the cheap $1 can stuff it will react and make an oragen peal effect
Old Dec 23, 2004 | 05:39 PM
chevy35086's Avatar
Axle/Gears: 3.42's
aigth
i have to find a local store
im in south jersey
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
